Question about Kodak Office Equipment & Supplies
New printer Kodak ESP 5 Error code 3821 - Kodak Office Equipment & Supplies
    Problem Solver:
  • 19 Answers
Ok i guess i need more information regarding the error code you are recieveing .... exactly what are you trying to do that prompts this error code to pop up ?
Posted on Aug 19, 2008
Kodak esp5 error code 3821
Posted on Apr 11, 2011
Paper jam, paper cleared, ink cartridges and ink carriage removed and cleaned. Printer error 3821 appears on screen. Press OK and screen says please wait and there it stays.
Your error code, 3821, means that the internal memory is screwed up!
Solution:
Unplug the printer for a whole minute for the memory to discharge itself. Anyway, that will force a memory reload and everything will be just fine.
Also, here is an alternate fix if the one above (which is the fastest way) does not work: Open and close the front door, if this does not reset the machine, turn off machine, switch back on while holding the utillity/counter key, after you see a black dot in the corner of the lcd let go of the utillity/counter key. the machine will take a while to boot up, and when it does you will see trouble reset on the lcd, press the reset on the lcd, switch off the machine leave it off for 10 to 20 sec's and then switch back on. If this does not work you have a screwed fsr, if it does work, it might come back at some point if the firmware is not up to date , the latest is vR6
Aug 02, 2011 | Kodak ESP 5 Printer
Solution:
Unplug the printer for 30 seconds, and then plug it in again. If you want, you can wait a whole minute for the memory to discharge itself. Anyway, that will force a memory reload and everything will be just fine.
Apr 11, 2011 | Kodak ESP 5 Printer
My Kodak Esp 5 want scan and I received a error message after trying to scan
is this the error message you recieved 1-2000 or tricode code for example 235x892. please verify what error message you recieved. Now if your recieved an erro mesage numbers you may need to reinstall the software of your printer. please download the latest software and drivers of your printer at kodak.com/go/downloads
Nov 21, 2009 | Kodak ESP 5 Printer
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Nov 07, 2009 | Kodak ESP 5 Printer
Error code: 1 2007 esp 5 kodak what is this
Try to uninstall and reinstall the driver.. Run also the clear software of Kodak located at this site www.kodak.com/go/clear
Aug 17, 2009 | Kodak ESP 5 Printer
Will not let me install new printer ESP-5 CD
Kodak printer ESP-5 CD version 3.2 is not compatible with Vista. You will need to upgrade to Firmware 4.3 Windows XP/Vista from Kodak Printers. The drivers may be found here:
http://www.opendrivers.com/freedownload/280436/kodak-esp-5-all-in-one-printer-firmware-4.3-windows-xp-vista-download.html
Jul 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Does anyone know what error code 3807 on a Kodak ESP 5 all in one is? And....can anyone tell me why the dammed thing tells me the print head is not installed every time I turn it on?
found a solution for your error code 3807 "System status failed"
To resolve the error condition:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
  4. Wait until the printer is ready to use.
If the error condition continues:
  1. Remove and install the Printhead two times before closing the Printer Access Door.
  2. Wait until the printer is ready to use.
If the error is not resolved, contact Kodak.
Jun 21, 2009 | Kodak ESP 5 Printer
Wont except aftermarket printer cartridge error code "not recognized"
May be the cartridge is not detected by Kodak printer. Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges.The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 23, 2009 | Kodak ESP 5 Printer
Reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 16, 2009 | Kodak ESP 5 Printer
407 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
