Question about Samsung SGH-T519 Cellular Phone
Broken Dispaly Well it finally happened after a couple of years of abuse, my Traces' screen went someplace better. I would really appreciate if someone out there could lead me blindly through the steps I need to press to save my contacts to my T-Mobile SIM card as my phone still works -I just can't see what I'm doing. Anyone out there with a working Samsung T519 please help!
  • bddbud Nov 26, 2008
    hiĀ
    my phone dropped and the display is not working, its half black....now how do i repair it if possible...
For doing that, you will have both your contacts, calendar, messages, programs, and more, saved to your computer and if necessary, back to your phone memory or SIM by simply drag and drop operation.
Posted on Aug 25, 2008
Install and use Samsung PCStudio 3.2. (download it from samsung mobile web site). You can save everything in your phone to you PC using it software. It is not necesary to see the phone screen to do that. Hope it help.
Changed a broken screen on a olympus stylus 600, now black screen what went wrong?
I have had same problem. When you put the connector back on from the display you missed it. My service manual said to turn on the camera an slide around the connector an dispaly will come on or be wrong color. All you need to do is align the wires correctly for proper color an screen.
Mar 17, 2014 | Cameras
My sandisk cruzer 8gb was stepped on while in my xbox 360 and i wont light up nor come on when i hook it up to my computer how do i fix it
You could crack it open and resolder all the broken connections in it.. but.. your better off buying a new one. their a pita to repair.
Apr 11, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a Samsung SP-S4223 42in. EDTV.
This is called tiling and this happends because of a weak signal from whatever device you have hooked to it weather it be cable or a sat dish. Try checking and makie sure you have good signal to this. If this matter gets wrose then you would need a repairman. Thanks
May 24, 2009 | Samsung SP-S4223 42 in. Plasma EDTV
Program menu on panasonic pv-m2037
I found a solution to my problem...my son finally broke that TV and my husband found a better flat screen 32" and it works well with the Shaw remote. It sounds really good and great picture. And to top it off he only bought it for 50$ so it was a steal in Kjiji.ca. Maybe kijiji will solve your problem too.
Cheers!!
Feb 17, 2009 | Televison & Video
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Mio 168 screen problem?
Have you tried contacting microsoft about this at all?
I am really not all that familiar with this device so I recommend using the "Ask Me" function for a different expert as you did for me.
I can give you a couple of suggestions. I believe there is a reset pin on the device, find it and press it. Second, try removing the battery and leave it out overnight to reset it. If either works, let me know, otherwise I don't know that much about this problem and either Microsoft or another expert would be able to help you better.
I'm sorry I can't be more help.
Have a good day.
Oct 09, 2008 | Mitac Mio 168 Pocket PC
Missing segments on the display
LCD dispaly is standard,
the brightness is controlled on the display control baord mounted on the board that the dispaly cable plugs into, the gain of an op amp that controls the brigtness of the diplay is loacted on this board , check also the potentiometer located close to the connector and adjust that, but a quick visit to radio shack will get you a couple of cents worth of parts and a few mintes of delicate soldering and a couple of hours of dissasembly , tracing and reaasembly. with a risk of doing further damage.
equally likely to a faulty power op amp or potentiometer is that the dispaly is expiring ( it happens sometimes to these types of plasma displays.....)
so if you are determined not to get a cheap relapcement cd 20 and are determined to open the beast. get a cheap broken cd20 unit and take the dispaly out of that one and replace it with your display ( by display i specifically mean the intergarted circuit tht the plasma screen is mounted to, and subsequentially screwed into the inside face of the cd 20 unit behind that bit of smoked glass,
which of course you are going to open and clean before you put it all back together gain.
have fun ;-)
Dec 30, 2007 | Bose Lifestyle 30 System
Likom Futura LDF770
There may wrong setting of refresh rate. Most monitors work at 60 to 70 Hz refresh rate. Above that they tunned blank screen or out 0f range message displayed. Also check the output video signal. Please confirm technical specifications from the documentatation of the monitor.
Aug 15, 2007 | Likom Futura LD7 17" CRT Monitor
Samsung SGH-T519 Cellular Phone Logo
98 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
