Question about Olevia LT42HVi 42 in. LCD Television
Olevia 540-B11 Hello all, This is the situation right side of screen dark from upper right corner to bottom right corner. TV does not respond to remote immediately turns on with blue screen and remains at blue screen for atleast 20 min. When choosing DTV it gives a no signal message on the right hand corner I then have to power off and on several times to engage the channels. No cable or satellite just basic HD antenna. Recommendations
  • Anonymous Mar 21, 2014
    there is a small screen on the upper right corner
    New Friend:
It looks a firmware problem, but the support is out f bussines...
Must be upgrade
Posted on Nov 26, 2015
Damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
Posted on Sep 06, 2008
I need the Manual for the Olevia 537-B11 TV
Try Googling (olevia)(537-B11)(manual) without parens.
May 29, 2017 | Olevia Televison & Video
Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
No picture but have sound on my olevia 540-b11 tv
Ur LCD inverter board it dead,must replaced to get picture back.It usally a long board inside the tv.Tries Shopjimmy.com,Ebay.com for the board part.
Jan 16, 2010 | Televison & Video
I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Dec 17, 2009 | Olevia 332V LCD TV
I have a 39-month old 40
Same exact thing here can you let me know if you find anything? patpmcc@yahoo.com
Dec 05, 2009 | Olevia Televison & Video
Olevia 337-B11 how to connect to a TV
Unfortunately, This hdtv can only use with receiver. There is no cable connection back of it. You may connect it using with HDMI cable.
Nov 30, 2008 | Olevia LT37HVS 37 in. LCD HDTV
OLEVIA 540-B11 42" LCD-Inverter supposedly shot craps
Ok I'm Not an expert on Olevia's but I've done enough LCD Tv's to know a few things. The inverter boards are usually located on the right and left side edges at the back of the chassis. They usually run from the top to the bottom and have multiple connectors coming out to feed the backlights in the LCD panel. I can believe Olevia might not supply them (most other companies do) except as a part of the LCD panel. In some cases, the manufacturer of the LCD panel (Olevia does not make their own panels) does not supply the boards separately to the company making the set..In terms of getting a diagram, the panel maker (probably chinese or korean) probably has one, but Olevia may not. Your best bet would be to keep an eye on a site like this one:
http://www.shopjimmy.com/
They get scrapped TV's and remove the inidividual boards for resale. I have already checked and they don't have the board you're looking for right now, but that can change. Sorry I can't be of more help!
Nov 07, 2008 | Televison & Video
Olevia LT42HVi 42 in. LCD Television Logo
436 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
