Question about Motorola Mobility RAZR V3
Motorola V3i I have the motorola V3i cell phone. Just @ 8 hrs ago I stopped receiving incoming calls on the phone. It doesn't ring on incoming calls, but ringer is working and wide open. It also doesn't show that i have v-mail even when i know I have some. Any suggestions? Thanks, Mike
    Problem Solver:
  • 14 Answers
Two possibilities:
First, if you haven't already, try turning on and off your phone - sometimes it can get stuck in a mode that would cause your problem, but restarting the phone may fix it.
Second, if that doesn't work, it's possible there is something temporarily wrong with your local cell phone tower that it is not transmitting calls or voicemails. You may wan to try your phone in a different geographic area and see if you have the same problem - if it's fixed when you move, you should contact your carrier to tell them about the outage at the local cell tower. (Although hopefully they already know.)
If none of that works, it's possible that some of the operating system software on your phone has been corrupted and you will need to do a hard-reset of your phone to restore defaults. (Warning though - this would erase the data on your phone so make sure to download any important files you have on it like photos if you want to keep them!)
Finally, it's also possible there is something physically wrong with the hardware (e.g. if a piece got loose or your dropped it), and you will have to bring the phone into your carrier to get it repaired or replaced.
Posted on Aug 19, 2008
No sound on incomming calls
Hi,why it does not ring out is because,the ringer is damaged..and it needs replacement. Before you replace it,you can clean up where the ringer is,there might be dirt stopping it to work.But you have to unscrew the phone to see where the ringer is.
Please if you have no knowledge about the phone,you can contact a skillful personnel for assistance.
Before that you can trythe below step,might just be a setting problem.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Have a nice day.
Sep 19, 2011 | Nokia C3 Cell Phone
The problem is every incoming call rings once then goes straight to voicemail before i can answer
Please check if any call divert or incoming call barring (found at settings menu) are actives .
Feb 11, 2011 | Motorola Mobility RAZR V3i Cellular Phone
My phone only rings 3 times for incoming calls
There is no such option in motorola as i know to extend duration of incoming ring.
Apr 28, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Unknown callers wont ring
maybe check on the ringer type for restricted numbers- you can change ringers by all calls, restricted calls, and caller id numbers. your incoming restricted numbers is probably set at none or silent
Apr 20, 2009 | Motorola Mobility Moto Q
Motorola v3i
you may need to reset and clear the phone then try again if that does not work then you can try a reflash of the firmware on the phone
Apr 19, 2009 | Motorola Mobility RAZR V3
I have no sound on incoming calls unless the phone is on speaker.
Try putting the phone on silent mode and then back to ringer.
David
www.cellunlock.net
Feb 03, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Motorola v3i
you would have to saved the contacts on your phone memory then assign ringer id to them and pics as well.
Nov 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Can Not Make Outbound Calls
you need to check the phone settings to se if you have the call barring feature set, if it is then remove it
Nov 02, 2008 | Motorola Mobility RAZR V3i Cellular Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility RAZR V3 Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
