Question about Brother MFC-5840CN All-In-One InkJet Printer
New ink cartridges not printing
Help! Just purchased new cartridges and the printer will not show any ink when printing.
  • John Desmond Sep 07, 2008
    Brother 5840CN black stopped printing with non--Brother ink cartridges. Installed full set of new Brother cartridges. Color print is O K. But no black. Have run clean cycle seven times with no effect. What do I do now. J Desmond
    Problem Solver:
  • 8 Answers
Hi,what kind of printer u used?,,,,i think u must repel the cartridges before using it.
Posted on Aug 19, 2008
After inserting new cartridges jobs no longer print. If you go into maintenance mode on the printer it scrolls a message "align cartridges" across the display. If you press the Check mark button at that...
Are you using Dell Series 9 ink cartridges? Dell Series 9 ink cartridges have a sensor that cannot be reset. Article on refilling Dell ink cartridges
It is possible to get a Dell Series 9 ink cartridge with a bad sensor. Take it back to the place of purchase for a replacement.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
I have a new Epson Stylus NX300 Series. When I
Diane,
We try to steer people away from new Epson printers unless they plan on purchasing a professional model. The new Epson cartirdges have little ink and finicky. I would try power cycling the machine with the cartridges removed (unplug it for 30sec.) then reinstall the cartridges. If the problem persist call Epson and let them know what you think. If they don't help you, buy an HP. But but an HP that takes integrated print head cartridges or you'll be in the same situation.
Pat.
Feb 02, 2010 | Epson Stylus NX300 All-In-One InkJet...
NOTHING SHOWS UP
While waiting for more info from you, Look for these :
If you have bought a new cartridge:
Make sure you purchased the right ink.
Make sure you removed the tape covering the print head.
Make sure you have installed the the cartridge correctly.
Look for the expiration date, old cartridges dry out!
If you have had the cartridge in the printer for a long time the ink might have crusted on the print head take out the cartridge and rinse the print head under warm tap water for a minute or so. then dry the hole cartridge thoroughly with a paper cloth OBS! don't rub the print head too much! put the cartridge back in the printer. If it doesn't help, maybe it is time to get a new cartridge!
Happy fixing things!
PLZ, Don't forget to rate!
Bruce
Feb 01, 2010 | Office Equipment & Supplies
Ink shows empty when toner is not even close to empty
there is one thing that if you refill the cartriage and then use again then still ink indicator shows low ink as its' ckt is designed so.
there is no problem you can print easily.
your printer will show correct ink level when you put in new cartriage.
but remember one thing that if your printer stops printing and shows message on computer that no ink in cartriage ,, then you need to reset printer counter, (this resetting process is present in your printer manual)
so no problem in printing, it shows low ink because the circuit inside it is designed soo.
so that you purchase new cartriage.
(remember : you need to reset the counter , refer to manual)
Jul 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Lexmark X2550 ink cartridge refill
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Mar 31, 2009 | Lexmark X2500 All-In-One Printer
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
Unable to print.
NO-ONE REPLIED TO THIS THIS PROBLEM YET.Please someone should know something????
Jan 26, 2007 | Canon Selphy CP510 Thermal Photo Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
