Question about Philips Televison & Video
Philips 42FD9954 plasma panel will not switch on from cold....green light on for 10 seconds then click and goes to flashing red.....if you switch on and off about 15-20 times it will eventually activate....
Disconnected all external power i.e. power lead, extension cord and wall socket...then reconnected...has worked perfectly since.
Posted on Aug 20, 2008
SOURCE:
My Plasma 42FD9954 42 TV doesnt work
Familiar problem on Philips Plasma units. PSU or Sustain board failing.
Jan 16, 2013 | Philips 42FD9954 42 in. Plasma HDTV
I have a phillips 42fd9954 17s. when i turn it on the green light tuns on for like 6 seconds then fades . then nothing. no sound no picture. any idea. i am using a comp cord. had no cord when i got it
if you use vga input and there is no signal the tv shuts down in few second. It will wake up again if you provide vga signal or cycle it on off again. Change input to component or s-video and tv should stay on. On the other hand, this model has known problem with bad power supply unit but usually red light flashing when tv shuts down in that case.
Oct 16, 2011 | Philips 42FD9954 42 in. Plasma HDTV
Model:Philips 42PF9965 Plasma At switch on the green light comes on for a few seconds,then it goes off and the red light starts flshing.After several attempts the tv may come on live and stay on until you...
You might have some swollen capacitors on your power supply board. They will be easy to spot out, because they will not have flat tops like the rest of the capacitors. Replace them with the same rating capacitor. You will need a soldering iron, solder and solder wick for this repair. If you are not comfortable with electronics I would recommend taking it to a authorized service provider.
Apr 14, 2011 | Philips 42FD9954 42 in. Plasma HDTV
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips 42fd9954-175
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
May 13, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Any ideas?
1) Replace C2663 by 2020 021 91677 (100uF/50V, 105°C).
2) Place Schottky diode 9336 247 60133 on pin 7 (+) and 8 (-) of IC7650,
to avoid negative pulses, resulting in this bad startup behaviour.
Mar 25, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips Plasma NO LIFE
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Dec 21, 2007 | Philips 42HF7444T 42 in. Plasma TV
Philips 42FD9954
Hey I have the same problem with my 42fd9954/69s. The best solution that I found that works everytime is I have taken the back off my plasma hung it on the wall. Then when I need to turn it on I it starts clicking, so I get my $10 room heater and blow some hot air down the back of the tv from the top and 30 secs later the tv will turn on.
Too easy. Bit dodgy, but I am a uni student!
Nov 08, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
