Samsung TXJ2566 TV Logo
Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the weight of the Samsung ws32z409t - Samsung TXJ2566 TV
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Jun 10, 2011
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2822803
Points
26282
This tv weight about 50 pounds.I had this type of Flat CRT tube tv before.Carry it upstair and down stair all the times,one day just weight it on the foot scale just for the heck of it.
2answers
What is the weight of the Samsung LA40S71BX
Tried to find the info for you. suggestion is to make the barcket to hold 50 lbs.
3helpful
I cannot print heavy paper. It consistenly jams. My HP inkjet prints the same weight of paper easily. Suggestions?
The maximum paper weight that should be used on the CLX-3175 is 163gsm, so if you use thicker paper it would jam.
Couldn't print on carton paper
The maximum weight is 150-160g not only for Samsung. The KonicaMinolta laser printer had maximum 164g paper weight. Too thin for business cards.
I AM BUYING A NEW TV STAND AND I NEED TO FIND OUT THE WEIGHT OF MY SAMSUNG TV?. MODEL LE40A456C2DXXU
The most basic details of the new Samsung LE40R74BD LCD TV include its weight and dimensions and both make this new model of phone very much attractive. This device has a weight of 22.8 Kg, a height of 71.3 cm, a width of 99.1 cm and a depth of 32.6 cm making it very compact and manageable. The black colour of this model of LCD TV has made its looks very much attractive as well as impressive.
Hope this solution is helpful?
2helpful
Picture stretched on samsung ws32z409t tv
Sometimes on a remote theirs a zoom button or HD zoom if you pressed that the tv will do what you describe if you press it again it will go back to normal view.
No longer printes perfectly horizontal on forms, now left side ok and right side drops down a little
Sounds like toner smear. The causes can be:
1. The weight of your paper exceeds the recommended paper weight for your printer.
2. The inside of your printer needs to be cleaned.
3. The toner cartridge is empty and needs to be replaced.
To correct this problem, try the following steps in order. Between each step, close the printer or make sure it's closed, turn it on, and then print a test page to see if the problem has been corrected.
1. Use only the recommended weight paper for your printer. Samsung recommends the following paper weights: 16 to 24 lb. (60 to 90 g/m2) for the main paper tray with multi-page feeding and 16 to 43 lb. (60 to 163 g/m2) for the manual tray and for the tray with single page feeding.
2. Clean the inside of your machine with a moist cloth to remove any dust or dirt inside. Note: DO NOT spray water directly into the printer. Spray the water on a cloth, and then use the cloth to clean the inside of the printer.
3. Replace the toner cartridge.
3helpful
Samsung camera wont work
my camera wont work on my samsung u600 it says please weight and after that it says check camera connections can u help me
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
