Question about HP DeskJet 5150 InkJet Printer
HP Deskjet 5150
How do I put in a new ink cartridge?
    Novelist:
  • 183 Answers
Posted on Aug 19, 2008
HP Deskjet 5150 poor print quality
For poor printing problems I suggest you run the Tap 10 diagnostic print test (see link to video below).
If the new (or refilled/reman/compatible) HP 56, 57 or 58 ink cartridge refuses to print black/color and/or function at all (i.e. blinking ink light on Deskjet 5000 series printer) or fails to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), the rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. It is suggested you perform the TAP 43 (and TAP 10) DIAGNOSTIC PRINTER TEST to evaluate the ink cartridges electrical performance. Visit Inkjet411 support site to see instructional video: http://inkjet411.com/?page_id=2358
NOTE: For the HP Deskjet 5000 series printer models, when you get an HP 56, 57 or 58 integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels are not initially reset. However, continuing to use an ink cartridge which displays LOW INK alerts is permitted by the printer, simply select OK, CONTINUE or DISMISS when these alerts are observed. Now, it is possible to reset the ink levels by performing the procedure outlined on Inkjet411's site: http://inkjet411.com/?page_id=1915
To clean the HP 56, 57 or 58 ink cartridges please visit the Inkjet411 site which provides recommendations on how to clean the electrical contacts, flex driver cables and how to perform a hot water flush of the nozzle plate (refer to video): http://inkjet411.com/?page_id=1519
Jan 17, 2013 | HP DeskJet 5150 InkJet Printer
How do you install ink cartridges for the hp deskjet 5150
You need to remove the piece of tape from them than place them in the holder and push down the lid it will than snap in place,it seams as you will break them if you push it but it wont unless you really put to much pressure.
Apr 09, 2010 | HP DeskJet 5150 InkJet Printer
Hp deskjet 5150 just replaced both inks...black
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 31, 2009 | HP DeskJet 5150 InkJet Printer
HP 5150 REPLACED BOTH CARTRIDGES LIGHT STILL BLINKING AND WONT PRINT
Don
Nov 19, 2009 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 , ink problem :S
replace the cariridge because when you refill the sensor gets triggered and the cartride is unusable.
May 08, 2009 | HP DeskJet 5150 InkJet Printer
Hp 5150 deskjet says that it is low on color ink
The low ink warning is actually normal for remanufactured cartridges. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. The prints should still be the same quality. You can either press the "Resume" or "OK" button to continue printing, or go into your printer settings and manually disable the ink level indiactor.
Feb 07, 2009 | HP DeskJet 5150 InkJet Printer
CLEAN INK PADS ,
The print head is integrated with the print cartridge itself. If your print quality is degraded, try searching on Google for a way to clean the print cartridge with alcohol. Or it might just be time to buy a new cartridge. In that case, do another search on Google and learn how you can earn money by sending in your old printer cartridges for recycling, instead of just throwing them away.
Oct 31, 2008 | HP DeskJet 5150 InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
Question for printer hp 5150
Ink has leaked into the printer and messages say problems with colour/black ink cartridge. Would cleaning the ink out of the print solve problem and if so what solvent is best to use.
Graeme
Apr 21, 2008 | HP DeskJet 5150 InkJet Printer
HP DskJet 5150 will not print black
re-install the print drivers. if it still doesn't print problem lies in the bubblejet power supply - not user fixable
Sep 06, 2007 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
Ben Johnson
