Question about Sony Cyber-shot DSC-W55 Digital Camera
I just bought a sony cybershot DSC-W300 and I charged the battery fully and i have a 4 gb memory card in it free of space but every time I turn it on it tells me to turn it off and on again. It will allow me to browse the home options and other options but I cannot take pictures because it keeps on telling me to turn he camera off then turn it back on. Please help me
  • carebear266 Nov 24, 2008
    me too, all of a sudden started happening yesterday? did u figure out a solution? if so I would love to know carebear266@hotmail.com
After looking at all issues on this problem online hundreds of people have had the same problem, the solution always suggested and sworn to work is to drop it!!! so after I kept reading and reading drop it, I did, about a foot away from the carpet and volia, it works again, I know crazy but my camera is working, give it a try.
Posted on Nov 24, 2008
Sony cybershot dsc-w300 free software
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 27, 2012 | Sony Cyber-shot DSC-W300 Digital Camera
Sony Cybershot DSC-W200 digital camera. Suddenly and for no apparent reason it can no longer be switched on. Blank screen, no lens movement, no sound, totally dead. I substituted a spare, fully charged...
Try this:
Remove the batteries at the same time that you remove the camera's memory card. This will allow the camera to reset. The camera does not require the memory card to operate, so leave the memory card out as you reinsert the batteries. If the camera turns on with the memory card out, but not with it in, you may have a corrupt memory card. Contact the memory card's manufacturer for a replacement.
Turn on the camera in playback mode. This mode allows you to turn on the camera without extending the lens. If your camera is already set to playback mode, it may appear the camera is not turning on when you press the "on" button, because the lens will not extend.Contact Sony if your camera still won't turn,if you bought your camera new from a licensed retailer, it should come with a one-year manufacturer's warranty. Sony Consumer Direct Return Center
10227 Crossroads Loop, Suite D
Laredo, TX 78045
1-800-236-1877
Sonystyle.com
Mar 24, 2011 | Sony Cyber-shot DSC-W200 Digital Camera
It is not switch on.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Mar 13, 2011 | Sony Cyber-shot DSC-W300 Digital Camera
My camera Sony Cybershot DSC-W180 when i turn on show"To use with compatible battery only" and after it turn off. I think is the battery but it isn't. please help me with this!
Feb 04, 2011 | Sony Cyber-shot DSC-W180 Digital Camera
My sony cybershot dsc-t200 will not turn on. None of the buttons or switches work. The battery is charged. For a while, it wouldn't turn on unless I put the battery on the charger for a few minutes first....
Yes its could be the battery ,have you try the power plug from the charger to see if its works if yes you may suspect the battery
because the ion lithium battery after a while of charging they come with a memory effect so when you charge it, they only charge a part
of the power and dont charge fully..
hope that will help you
regards Alan
Oct 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Aug 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Can't use the video function of my SONY CYBERSHOT DSC-T500
Please reduce memory stick size as 8 GB is too much for it and 2 GB would be fine in DSC-T500
Feb 10, 2009 | Sony Cybershot DSC-T200 Digital Camera
Sony DSC-S600
If you have a memory card in the camera, take it out before turning the camera on
Aug 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Format Error in Sony Cybershot
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Sony Cyber-shot  DSC-W55 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
