Question about Sony VAIO PCG-K35 Notebook
Hi I cant connect to the internet.
It says that the wireless connection is available but that my settings on my computer for the netword do not match the requirements. This just started happening today, I was always able to connect and now my daughters laptop is saying the same thing. Please help! My email address is KarateMommi@aol.com
  • Anonymous Nov 03, 2008
    I cannot connect to the internet via wireless.
    President:
  • 2,559 Answers
Try a reset on the wireless router,You can do this by unplugging it for a few minutes.
Posted on Jan 06, 2009
How do I engage tne wireless
With a wireless connection, your PC can connect wirelessly to a network printer.
In addition, you can set up your PC in a location where no phone line or cable connection exists.
Outfitting your desktop to a wireless Internet connection is very easy.
Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located.
If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs.
Also, some apartment complexes and college dorms have free wireless Internet.
Your neighbors may have wireless Internet too, which you can ask them if you can use.
Buy a wireless network adapter for your desktop.
You can obtain an adapter from most electronic stores.
Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot.
The easiest adapters to install are those that just plug into an available USB port.
Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter.
The usual procedure is to plug the wireless adapter into an available USB port.
Windows will install the appropriate driver.
After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars).
A list of available connections will appear.
Select the desired connection.
If you are prompted for a password, enter the appropriate password.
Click "Connect."
You are subsequently connected to a wireless network.
Launch your browser and enjoy surfing the Internet wirelessly.
If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel."
Then select "Network and Internet" and "Network and Sharing Center."
Click "Change adapter settings" in the left pane.
Double-click the icon of the appropriate wireless connection.
The Wireless Network Connection status window appears.
Click the "Wireless Properties" button.
Select the "Security" tab and select an encryption type from the drop-down selection.
Enter a password in the Network security key field.
Make sure that the password matches the router settings.
Press "OK" when done.
Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area.
You can buy these online, or at electronic stores.
You'll need to set up your router using the accompanying instructions and your own Internet service provider.
This is best in a home with multiple computers.
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled,
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
You only need to check the following if a driver cant be installed
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"
Jun 17, 2013 | HP Pavilion a6750f PC PC Desktop
Why can't my dell inspiron 530s desktop install
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers. Hope this helps
Dec 19, 2012 | Computers & Internet
Hi, I have brought a Wireless router (D-Link) and I am trying the connect my Toshiba notebook (L305D-S5892). In the available wireless netwroks it shows my network but it is unable to connect.The error...
There are a number of possible solutions for this problem. The best route may be calling customer support for Toshiba and/or the manufacturer of the Wireless router. I'm just brainstroming here, but when I tried to hook up my WII and XBOX wirelessly to the internet, I had to have a "G" connection. Further, you also don't metion the brand or model number of the router. My security setting also had to match there is WEP vs. 128 bit encryption, you have to make sure whatever the defult value is on the computer matches the network.
Usually there is a data plate somewhere on the laptop, probably underneath that will give you the model and serial number. There may be a customer support number nearby that you can call for futher assistence. I'm also assuming that you have "Windows" installed.
On my computer, I have the latest version 7 installed. If you're looking at the Desktop with no other applications running, press F1, then type in network connections, click search. On my computer, the answer came in at number 8, "Why Can't I connect to a network?". There are other possible answers such as "Setting Up a Wireless Network." Most people don't realize that there is built in help with the computer.
Dec 04, 2010 | Toshiba Computers & Internet
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
Set a private connection for my internet
Set your password ... it is a part of the wireless setup wizard.
Easiest way to do this is delete the connection and re-discover it.
Go to the control panel ... open network connections and remove the wireless ... Reboot ... leet windows rediscover ... when you get the opportunity, set the password.
HELP has an excellent example for this.
May 26, 2010 | NetGear MR814 Wireless Router
Actiontec GT704WG doesnt connect to internet
HI! all your computer is connected except for one, you are connected to to the local network but cant get an internet connection, I dont see any problem with your wireless connection bcoz you are connected to the lan, check the security settings of your browser on your windows vista, go to internet option and security, lower it down to medium security, so that you can access the internet or try using other browser like firefox or google chrome.. check your firewall settings as well on your windows vista..
Aug 08, 2009 | Actiontec GT704WG Wireless Router...
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless router
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Jun 26, 2008 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
Wireless connection of netgear wireless router for compaq laptop
Sometimes firewalls on your computers can cause connection issues. I had the same problem with my home network. I had norton internet security 2008 on both systems, but the firewall settings on both computers had to be adjusted to allow the computers to talk. If you have different brand firewalls on each computer, you should consider to switching one of the computers so that it matches the other.
Another thing you want to do is log into the router's web utility and check to see if the wireless settings are blocking wireless connections in some way. You also want to make sure the ssid broadcast is enabled.
Finally, you really should consider using security on your router, so wireless connections would be password protected. I suggest wpa personal.
May 03, 2008 | NetGear WGR614 Wireless Router
Sony VAIO PCG-K35 Notebook Logo
65 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
