H5-01 I have gotten advise to enter the fuser reset code, but where do i access that code?? Error H5-O1
  • Anonymous Aug 26, 2008
    Code H5-01
  • Tim Babcock
    Tim Babcock May 11, 2010
    Whats the make and model of the copier?
    Problem Solver:
  • 3 Answers
What kind of machine is, i know it is a sharp from the code butwhat model.
Posted on Aug 19, 2008
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Tip
Brother MFC 8440 showing error code MACHINE ERROR 6A or 6E
Hi.
Both errors are signalling a temperature problem in fuser assembly.
The solution below applies to several Brother models. Depending on the model, the reset procedure may be different.
Brother Error 6A means that the thermistor located in the fuser assembly did not detect that required temperature had been reached in valid time.
First you can try entering in maintenancemode and clearing the error. If that does not work, that means that the thermistor, the lamp, or the whole fuser assembly must be replaced.
Error 6E is similar. 6E is diplayed when thermistor detect that the fuser temperature is not going up at least at 2°C every for 5 seconds.
As for 6A, first reset the code. If the error does not clear the fault can concern the thermistor, the fuser lamp or the power supply to the fuser assembly.
To reset the error code follows these steps:
1. Press MENU *,2,8,6,4 . Press keys within 2 seconds.
2. The machine beeps and display shows “maintenance".
3. Look for Init or Reset on menu, and enter the corresponding parameter.
4. To exit press 99.
This procedure above usually works on MFC-8xxx model. On other models you may need to do the following:
1) Unplug machine.
2) Hold down menu key. Plug in machine.
3) Release menu key.
4) Enter 91
5) Enter 99
or:
1) Disconnect the printer power cord.
2) Hold down the menu key while plugging in machine at same time.
3) Enter 99 while holding down menu key
4) After menu says " wait" push the stop/exit button to get out of the maintenance mode.
If that does not work, it means that the fuser assembly must be replaced. Here the part for MFC-8440: Genuine Brother Mfc8440 Fuser Assembly.
Regards.
on Apr 08, 2010 | Brother MFC 8440 All-In-One Laser Printer
Ir6000 error code e246-0002
fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
H5-01
Hello sir;That code means, fuser jam, fuser not installed or pcu main board/sub board, seem like fuser unit not installed.
Mar 22, 2009 | Sharp Office Equipment & Supplies
Error code C 6400
This code is a fuser problem code. Follow the procedure below. If the code does not reset or comes right back then: you will have to check the thermistor, thermo fuse and fuser lamp. If 1 or more are defective then replace. After you replaced the defective part you will have to clear the error code again.
Here's the way to reset that fuser code;
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Jan 27, 2009 | Office Equipment & Supplies
Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Dec 10, 2008 | Office Equipment & Supplies
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
H5-01
Hi, to reset H5-01 press these buttons: #, *, C, *, 14, start 'are you sure'- yes
regards
Andy
Jan 30, 2008 | Sharp AR-M237 Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
750 people viewed this question
jasbo
jasbo
