Question about Sega Genesis Console
Flickering power/screen It had been a while since I booted up my Genesis. I pulled it out, plugged it in (ac adapter and rf adapter) and turned it on. the game would run for about ten seconds, then reboot itself. Anyone have an idea on how to fix this? AC adapter issue? Console issue?
  • 52 Answers
Sounds like a dry solder joint at the power plug.
To make sure of this just plug the console in and turn it on (so the red light goes on) and gently move the power cord an see if the red led flickers; if it does then follow this fix
Open the console don't loose the screws!
Remove the circuit board and look at the power plug closely
There are 3 joins to it and the board.
Sometimes you can just touch a hot soldering iron on them or a small blob of solder will fix it. Then reassemble and have fun.
Posted on Aug 20, 2008
Sega Genesis Model 2 won't turn on
Well it sounds like that you have a bad ac adapter then so buy a new ac adapter the console is fine so just a new adapter that's all.
Apr 28, 2012 | Sega Genesis Console
Battery light is blinking on the dash of my 1998 k1500 and the daytime running lights are flickering also
Check your AC Adapter plug. If it's damaged, you may be getting intermittent breaks in contact. If you're not sure if it's damaged or not, pull your battery and try to boot up with just the AC Adapter plugged in. If it doesn't shut off, it's probably a bad battery. If it does, you need to get another AC Adapter or have the plug on the machine replaced.
Jan 30, 2012 | Cars & Trucks
Is the Sega Genesis AC adapter compatible with the NES? And is there a certain type of RF switch that you need for the NES, or are they universal?
Well for the nes ac adapter I use the offical adapter because its licensed Nintendo and thost 3 way adapters are very unrelaible then.
images?q=tbn:and9gcq9re-avicxr50vzdjwd-hgcyqhiumdjm_yyrkhdiysfgstd7ro6t6upka images?q=tbn:and9gctxvoqhxkgkyuseoqg6ehxd_i9ehvvmd9sn5edjzjijrqqqdyl6wxi2rdvz
Oct 19, 2010 | Nintendo NES Console
Yellow light flickers 4 times when trying to turn
If you don't get the flickering lights when you try to boot up with the AC adapter hooked up but no battery, it sounds like the problem is most likely a bad power adapter. Your battery is dead, and that's why you get the flickering lights, but the AC adapter is bad so you can't use it to power the laptop or charge the battery.
You can typically get a new adapter for $20 or so, or maybe even cheaper on eBay.
May 29, 2010 | Toshiba Satelite A10 Notebook
When i plug in me sega genesis and plug it in to the t.v. no screen comes up not even a black screen how do i fix it
Check these things first:
1. The power supply puts out enough voltage and works okay.
2. Channel selector switch is in the channel 3 position.
3. Replace the AV/RF cable with a known good working one.
Does the Genesis power light come on?
Apr 15, 2010 | Sega Genesis Console
Sega turn on but just get squiggly lines help!
I've seen Genesis consoles that are just plain bad, rusted inside and screwed up, no fixing that. I hope that isn't the case but it sounds similar to what happened to me, and mine was garbage.
make sure its on the right channel (3 or 4 depending on the RF switch). also wiggle the A/V cable to see if its a loose port. Try holding the cartridge back or forth when powering it on in case the pins that touch the cart inside the console are loose and just aren't making contact (if this is the case there are guides on how to open up the Gen and make them stick out more, fixing it)
Best of luck!
Jan 07, 2010 | Sega Genesis Console
Sega Genesis Video Problem
Maybe you are supposed to be on Channel 4. There should be a 3-4 switch on your RF adapter. Try wiggling the video connection in the back of your genesis and see if that fixes anything, it might be a lose port, in which case you have to wrap the cable underneath the genesis or something heavy to keep it at a working angle (if you find a working angle).
It is also possible your RF cable is bad. They aren't that much on ebay, but make sure you buy one for your model (there are 2 models of genesis and they use different RF cables)
I hope this helps somewhat.
My sega genesis wont work!
Really most of the time it just takes a little wiggling in the back of the sega because i always get this problem with mine with the oldstyle rf adapter set to ch.3 but after i move it just right i get clear picture
Mar 28, 2009 | Sega Genesis Console
Power, But No Picture!
Try moving the a/v or rf cable in the back of the genesis
Mar 03, 2009 | Sega Genesis Console
Sega Genesis Console Logo
291 people viewed this question
Top Sega Video Game Consoles & Games Experts
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
