Question about KitchenAid Dishwashers
Dishwasher lacks water pressure
My 4 year old kitchenaide dishwasher is not producing enough water pressure to turn the washer arms. I do not see any debris blocking the screen. I am wondering if the impeller needs to be replace?
Bob
  • 1,800 Answers
Yes that what gonna solve the probe
replace it with the proper one
plz rate e as fix ya
Posted on Aug 19, 2008
Not cleaning
Check spray arm jet holes. Clean the clogging with blower or soft bristles.
Apr 12, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
My kitchenaid dishwasher is not cleaning the dishes on the top rack well. It is nine years old.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Jul 08, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Not enough water Pressure to clean dishes, 6yr old Bosch
Replace the pump, if you go through the trouble of repairing the pump and all the disassembly and then more problems will probably ensue. As far as location it is usually located under the washer. Accessed through the front service panel. Make sure you follow all safety procedures #1 being unplug the washer or turn off breaker prior to proceeding.
Feb 13, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
No water flow through dishwasher
No you need to clean out the spray nozzles with an old toothbrush etc both top and bottom and also clean out the debris filter below or at the heating element at the bottom of the washer. Then run a bottle of dryright etc. to help clean up the buildup in the machine. Then do this once or twice a year from now on and that washer should work great. Hope this helps.
Jan 18, 2009 | KitchenAid 24 in. KUDI02FRSS Stainless...
E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
KitchenAid KUDR01TJ Dishwasher Cleaning Problem
Sinder...this sounds more like a water temperature issue than anything else. First, turn on your hot tap. If you can't hold your hand under it after it fully heats (over 125)...you should be okay. If not, raise your water temp or use the sani cycle to raise the temp. Change brands of detergent. Salt...I don't think so. You're using detergent...not soap...which would have been affected. Pressure should not be an issue...once the unit is filled, it makes its own pressure recirculating with the wash pump.
Oct 13, 2007 | KitchenAid KUDR01TJ Dishwasher
Dishwashers Logo
98 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
