Question about Weber Genesis Silver A Grill
I have a weber E320 grill and it is making a fairly loud humming sound by the connection of the tank. I just had the tank filled and checked for any leaks. It was determined that the tank is not the issue. I can get the grill started and running, however the humming continues throughout the grilling process. Should I be concerned? Do I need to replace the connector to the tank? Thanks in advance for any help you can provide! .
  • Mike Hollander
    Mike Hollander Aug 02, 2017
    It is the gas flowing through the diaphragm of the regulator. It is common here in South Florida where we have alot of humidity. It is nothing to be concerned. You can also spray soapy water around the regulator fittings if you are concerned of any leaking around the regulator.
    Problem Solver:
  • 11 Answers
Posted on Aug 02, 2017
SOURCE: Weber grill
Can you tell if the gas is flowing? Its either dirty or perhaps your regulator got damaged.  I'd check that out.  Above all else, though, be careful!
Posted on May 19, 2008
SOURCE: Weber Silver B grill
I bet your grill gets no hotter than about 300 with the lid closed?
The tank has a built in safety feature. If a burner is left on when you open the valve on the tank, or turned on too soon immediately after opening the valve on the tank, the flow will be restricted. You need to turn all burners off, close the tank valve, disconnect the tank, reconnect the tank, open the tank valve, waqit a few seconds, open the burner valve and light. You'll get unrestricted flow and much better heat.
Posted on Jan 11, 2009
cdenham1st
  • 3 Answers
SOURCE: my weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Posted on Mar 21, 2009
onyxvu
  • 74 Answers
SOURCE: weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
Posted on May 26, 2009
  • 15 Answers
SOURCE: New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Posted on Apr 16, 2010
My weber grill (I think Model Silver B) has started to make a small hissing sound when I turn on all three burners. Just replaced the propane tank and it seems to be doing the same thing. Any...
Depending on how loud the hissing is! If it isn't very loud it is probably corrosion on the burners. If your blames are more yellow than blue, you have corrosion building up. So I suggest using a wire brush to clean it up and then using a small ice pick to clean the gas outlet.
Aug 30, 2011 | Weber Genesis Silver B Grill
I have a weber genesis grill. just refilled the tank and connected it. this afternoon my wife smelled gas near the unlit grill. There was also an intermittent hissing sound. could the heat of day 90 plus...
seems like I can always smell a little gas on a freshly filled tank until I use it down a little bit. Also there is a bleed off screw on the valve of the tank Make sure it is tightly closed
Aug 09, 2010 | Weber Genesis Silver B Grill
The second burner on my weber grill makes a humming sound.
Sometimes, under specific atmospheric conditions, the regulator will hum. This is not a problem in most cases, but if you put on a new regulator and hose it may correct the problem.
Jul 07, 2010 | Weber Genesis Silver B Grill
We have a new Weber Genesis LP gas grill. The
My thoughts, are you turning tank off after cooking, not only turning of cooking valves but also turn off tank, if you don't gas will leak out. If you do turn tank off, then you have a leaking valve in the tank.
Jun 13, 2010 | Weber Genesis E-310 Gas Grill
Weber Spirit one month old...went out, changed tank, won't light
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Apr 26, 2010 | Weber Spirit? E-310 Propane Grill
Low heat from weber grill
turn tank off disconnect from grill make sure all knobs are turned off including side burner reconnect tank make sure fitting is all the way on tank turn tank on and try again
Aug 15, 2009 | Weber Genesis Silver C Grill
Noise / vibration from gas regulator
This is on the Weber site, under support. I have been experiencing the same problem and have not used it because of it.
Humming or whistling from the regulator: Outside temperature, humidity, barometric pressure, and the gas level within the tank may cause the rubber diaphragm inside the regulator to vibrate, making a humming or whistling sound. Although this sound may be alarming, this is NOT dangerous as long as it is not accompanied by the smell of gas. If the humming sound persists, a change in atmospheric conditions will eventually stop the vibration.
Jun 03, 2008 | Weber Genesis Silver B Grill
Weber Genesis Silver A Grill Logo
331 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
