2002 Nissan Sentra Logo
Posted on Aug 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2002 nissan sentra ser spec v. my car wont start, im not sure if its a timing issue. i had changed the head gasket and when putting everything back i installed new cams. i pulled a plug out and left it connected to the coin on plug boot to see if im getting a spark to my plugs and im not getting a spark to all four coils. i dont know what else to do, can you help me?...
tace899
Level 2:
Sergeant:
  • Nissan Expert 291 Answers
  • Posted on Aug 29, 2017
tace899
Nissan Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
80108
Points
751
The coils are fired from the OBD box. If you changed the cams, make sure the pickup timing marks on the new cams are the same as on your old cams. The OBD reads the position of the cams from a sensor, which picks up the cam position from the cams themselves. If there is no signal, or a faulty signal from the cam sensor, the OBD will not fire.
5 Related Answers
Anonymous
  • 75 Answers
  • Posted on Jul 26, 2008
SOURCE: nissan sentra ser spec v
free the engine from the compressor and then remove the plug then first insert the drive belt on the smaller pulley side and after that try inserting the belt on the larger pulley side slowly by rotating the pulley slowly by stretching the belt with a rope
Anonymous
  • 41 Answers
  • Posted on Nov 24, 2008
SOURCE: Spark plug gap for 94 Nissan Altima
The correct spark plug gap is .044
Anonymous
  • 3533 Answers
  • Posted on Mar 20, 2009
SOURCE: replaced head gasket
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Anonymous
  • 1077 Answers
  • Posted on May 28, 2009
SOURCE: blown head gasket
That would be a lot to type out on the computer.
My best advise would be to get a Chilton Manual at the autoparts store. It cost about $20. You'll get all the info you need plus pictures and diagrams. The Chilton book will be the best research material for the type of job you are going to do.
Anonymous
  • 11 Answers
  • Posted on Sep 29, 2009
SOURCE: I have a 2002 nissan sentra SE-R. when the engine
Got the same make/model/year, but haven't had that problem. Does your temperature gauge run at half or above when this happens? If so, start with a cheap fix - new thermostat.
Another thing to consider is that some of the QR25DE engines equipped in the 02 Sentra SERs has an active recall on the crank position sensor. This fault would cause the check engine light to come on and the car would stall unexpectedly. It should start back up but the frequency of this will only increase without repair.
Also, no need to change plug wires, you have coil pack ignition - there is no distributor. If a coil pack is bad, you will have constant misfire and SES light.
I have a 2007 nissan sentra ser spec v 6 speed car. The car is losing power in 5th and 6th gear while pulling the pass out of seattle. Any suggestions on what it could be?
change transmission fluid and filter. Check for blown gaskets on valve assembly. Clean throttle assembly with anti soot fluid.
I have a 2002 Nissan Sentra spec-v ser 2.5 cvtc manual replaced battery & the engine cranks but will not start. I've replaced the 80a battery IGN fuse & the 120a battery fuse but did not...
I have a 2003 Nissan Sentra SER SPEC-V and have done all my own work. When the battery was replaced, was the Positive battery terminal taken off first, before the negative terminal? whenever doing work on a car with a ECM, the rule is: Negative terminal is ALWAYS taken off first, then the positive terminal. After changing battery, the positive terminal is put on first and then the negative terminal is put on last. I am not saying that you have an ECM problem but they can be damaged if you take off the positive terminal first.
Do you have any "check Engine Light" code issues? If you do, and you have access to an OBD2 code reader, check if any trouble codes come up. If you do not have access to one, you can go to an Auto Zone or other parts outlet and they will read it for free. Confirm that you have or do not have any Trouble codes. Let me know what you find out.
1helpful
4helpful
2answers
I have a 2002 nissan sentra SE-R. when the engine is really hot, it dies in idle, the idle is 600 RPM, i guess the idle is too low. So I have to rev it when im at the stop light or double pedal if i make...
2helpful
2answers
Overheating 2002 Sentra after thermostat change
I have 2002 Nissan ser with 120k, and I noticed a different temperature change when I start my car up...it takes a while to get warm. The weather has been cold lately, but my car has quick jolt as I'm driving until the car warms up. What is this issues I'm having...?????
2002 Nissan Sentra Maintenance
i would get the 90k major service done and i would also have the hydraulic chain tensioner replaced, have ur battery... chargeing and starter system checked as well..make sure u dont have corroded terminals at the battery.
2answers
2003 Nissan Sentra SE-R Spec V
I have the same car and I know there was a TSB for the ECM . I know the ECM issue has cause some cars to stall while driving
2answers
HOW DO I CHANGE THE TIMEBELT ON MY NISSAN SENTRA 2002 SE-R
you will have to take the whole front of the motor apart. it should be alot easier to go through the fender well to do this.
2answers
Nissan sentra ser spec v
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
