There will be an anti fire solinoid on the bottom of the carb bowl, the idea is to shut off the fuel in the main jet when the engine is switched off, you should hear a click as soon as the ignition is switched on, you can take it out and check that the centre pin goes in when the ignition is switched on. If it has an external vacume pump, it may not be working, these are fitted where there is no gravity feed to the carb from the tank, if the fuel hose from the tank goes to a component and then to the carb it does have a pump, pull the fuel hose off the carb and crank the engine, there should be a steady flow of fuel, if not check the vacume hose has not become detached, if ok replace the pump.
