Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Still dont get it!!
I cant find a place to plug the other side in but none of the holes are the size of the end of the plug???
If you still haven't been able to find the plug, there is a small tab on each side of the machine which alows you to flip the top open, the plug is in there.
Posted on Aug 28, 2008
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Ok..this must be something from another posting, eh?
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
I have a 4.6amp/ Hassle Free Weedwhacker that uses green plastic strings. Can someone tell me step-by-step (or diagram) how to insert one into the three holes?
Should have only two holes that are the same size. Forget the third. Place the plastic guard cover on the head first, make sure the holes line up with the grooved tracks then snap cover into head. Take on end of the line and place into one hole until it comes out of the side of the head, (Then stop). Do the same with other end. Now pull both ends equally.
Sep 01, 2013 | Craftsman Garden
I bought a replacement fuel tank for my 1981 jeep cherokee wide trac and it has two holes in the top. two different sizes each with retainer rings. I know the larger one is for the fuel sending unit b
Come across this type of thing before they probably used the tank for later vehicles & that is reason for two holes.
The rubber seal is there as you state ask a dealer if they can supply the plug hole seal for the one your not useing, The year & Model is most important when speaking to the dealer. Best Wishes, Malcolm Campbell.
Jun 20, 2017 | Cars & Trucks
What is a step plug on a camshaft sensor synchronizer
Non-Step Style - If you look inside the connector on the Camshaft Position Sensor; you are looking at the socket (female) side of a quick connect plug. For the non-step style plug socket, the hole is the same size in the front of the plug socket as it is at the back (bottomed out in the socket hole) end of the plug socket. This means the tip of the plug (male end of the quick connect) from the vehicle will be the same size as the back end of the quick connect plug, (no step down in size.)
Step Style - If you look inside the connector on the Camshaft Position Sensor; you are looking at the socket (female) side of a quick connect plug. For the step style plug socket, the hole is large at the front of the socket, then about .25 (1/4) inches into the socket, the size of the socket steps down about .0625 (1/16) inches. This means that .25 (1/4) inches into the socket, the socket hole steps down and is smaller than the socket hole at the front of the socket. The smaller socket dimension remains this size the rest of the way back (bottomed out in the socket hole) of the plug socket. Looking at the vehicle side of the quick connect plug, the tip of the plug (steps down in size.)
Feb 17, 2013 | 2001 Ford Taurus
Under the car it looseing antifreeze a freez plug is how to replace and want look like. 2002 chrysle concorde with 2.7
Your motor has several freeze plugs. The freeze plug holes are located usually 3 per side on the block, 2 in the ends of each head and 2 in each end of the block. Determine approximately what location the coolant is running out from, feel around the block for an actual round hole/cavity in the block. They are different sizes. some as small as 1 inch diameter to as large as about 3 inch diameter. Find the cavity that is not filled, as you can stick your finger deep into the block/head.
Then measure this hole. The easiest type relacement plug is called an expansion type. It is like a rubber stopper that you tighten a bolt in the center of it to expand it/tighten it to the full diameter sealing the cavity. Found at most parts stores. They come in a variety of sizes, so you must try to get extremely close to the actual diamerter of the freeze plug hole in the block/head to make it work. Install new plug into hole pushing rubber portion in all the way until the flat metal washer part of the expansion plug contacts the block/head surface. IT MUST be flush or evenly seated in the freeze plug hole/cavity in the block/head. Tighten center nut on new plug to about 25 ft lbs. This will make the rubber part expand and seal into the hole. Refill coolant, check for leaks. In my experience, if you pop one plug, it is usually in the block first and one will be popped on both sides of the block. Feel around BOTH sides of block to verify all 6 plugs are in place! CAUSE>>
This is due to water in the coolant system freezing, due to poor coolant system maintenance. The freeze plugs pop out when the frozen water expands preventing the freezing water from cracking your block.You would be money ahead to drain/flush your system and refill with all new 50/50 antifreeze of the type recommended for your vehicle. NEVER put water in your cooling system! Use only in emergency, fix problem then drain and refill with 50/50 coolant! This will prevent this problem from reoccurring and damaging other cooling system components.
Jun 06, 2011 | 2002 Chrysler Concorde
I'm trying to replace the spark plugs on a 2000 olds intrigue 3.5L. Is there a place I can find a diagram of the plugs' location? Can I do it myself or are the plugs hard to get to?
You should see 3 plug wires on the front side of the engine,remove them twist and pull straight out,to remove the wires.do not get them crossed,but place them where you know they will stay ,since they need to go back to the same spot,or plug.
The back side may be more difficult.If you cant reach them from the top you may need to go from the lower side under the car!! hopefully you can see the wires and remove them and the plugs from the top. A short length of 3/16 rubber vacumn line is verry useful to reinstall the plugs back into the plug holes,since the plug socket may be awkward,and you dont want to start them cross threaded,esp if the heads are aluminum.And if they are they need to be coated with anti seizeing compound! A gray looking grease!
Make sure the plugs have the right gap! Dont drop them on the dirty ground or hard concrete,if you do clean them and regap! Take your time,if you can and you may save some $$$$ good luck!
Aug 30, 2010 | Oldsmobile Intrigue Cars & Trucks
Have a 2003 chevy silverado 5 speed can not find the filler hole in the trans to check the fliud
the 5 speed trannys dont have holes to check the fluids only automatic ones.
Jun 22, 2010 | 2003 Chevrolet Silverado 1500
How to replace freeze plugs in 1998 ford explorer with 4.0 engine. Center freeze plug on driver side came out with rust around it. whats the process of repair?
make sure there is no material from the old plug left in the hole. clean inside hole with light grade emory cloth. put some hi-temp sealer on the mating surface of the plug. tap into place hollwed side out, edge flush with the engine surface. measure the hole precisely to get the correct size plug. access to hole may be limited.
Feb 25, 2010 | 1998 Ford Explorer
My refridgerator leaks water every two weeks
check to make sure the drain pan is in the right place. If it puddles up inside the bottom of the fridge first, your drain hole is plugged up. for this, you wil have to remove the access panel in the back of the freezer side to get to the drain hole. you may also have a crack in your drain pan.
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
I don't know how to attach my speakers to the red
If you have bare ended wires , you simply unscrew the red and black plugs at the amp they should have a hole in the end of the plug and on the side also just place the red wire into the side hole of the red plug and finger tighten the red screw the same on the black plug
Jun 06, 2009 | Polk Audio RTi100 Main / Stereo Speaker
Disk finalization error
dont know if youve found a solution already, but:
you cant finalzie the disc using battery power, you need to use the ac adaptor. This is something you should have got with the camcorder. its basically the charger plus another cable. so, plug in the charger to the mains as normal. then remove the battery from the camcorder, you'll notice a round hole in the camorder, this is where you plug in the cable i mentioned earlier, the other end of the cable goes into the same size hole found on the battery charger. that's it - you now have power to the camcorder from the mains. switch on the camcorder as normal and finalize the disk.
Jan 13, 2008 | Panasonic VDR-D100 DVD Camcorder
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
