I have a headset with the slide boom i lost the book and have too pair to a new phone
Electronics should always have a default even for a tech i used the default for my old bluetooth and used reconize any local equipment it picked up my blue tooth i just cant put it on trusted device list but i dont want to buy a new device everytime my phone crashes and info is erased
thanks luckyloo23
Posted on Aug 20, 2008
The pairing light on my HS850 soes not come on?
You have to start with the boom closed and press the large button with the phone symbol until the blue light comes on, then open the boom before the light goes out and you should be able to pair it with your phone.
Feb 26, 2010 | Motorola Mobility HS850 Consumer Headset
Want to pair existing motorola blue tooth head set with new phone, but can't get headset to go into "pairing" (purple) mode.
The center button must be depressed with boom "closed" until it turns purple. Once it is purple, let go of the button and extend the boom. It should then remain a constant purple color and then be in "pairing" mode.
Aug 28, 2009 | Motorola Mobility H700 Wireless Headset
Can not pair with my new phone
sure can
with the boom mic closed Push and hold the call button until the light around turns purple or stays a blue, then open the boom mic the color should stay on now go in to the phone settings and find the bluetooth settings and search for device once it finds it connecct to it, Remember the Passcode is 0000, and then you should be all set up.
Jun 28, 2009 | Motorola Mobility Bluetooth...
Sennheiser VMX100 Bluetooth Headset I lost manual how do i pair with my phone
In order to pair it with your phone, it must be in pairing mode first. If it has never been paired to another device before, just by opening the boom, the indicator light should flash alternately in red and blue, thus indicating it is in pairing mode. Otherwise, to force it to go into pairing mode, press and hold the volume (either + or -) whist opening the boom. It should flash alternately in red and blue. Only then, make the other device's b'luetooth application search for new devices. After a while, the VMX100 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful. Now, ot pair it with the other device (the VMX100 is able to pair to up to 4 different devices), make sure the previous device has its bluetooth radio turned off. Then, repeat the pairing process with the other device.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Feb 03, 2009 | Sennheiser VMX100 Bluetooth Headset...
Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Jul 31, 2008 | Motorola Mobility HS850 Consumer Headset
Skywing bluetooth
PUT H700 HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Then on your phone, search for new bluetooth devices and connect. the defaault code for the HS is 0000
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
Constant BLue
go to bluetooth on ur phone and select Hs850 delete device. then hold multifunction button until blue then open boom search for new devices from thee cell.
Aug 09, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
37 people viewed this question
 Grubhead
Grubhead
