Rolex Daytona 116520 Wrist Watch Logo
Posted on Mar 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1992 Rolex DAteJust- it runs great for several weeks .. of everyday use, and then it will stop for no apparent reason. After I shake it a few times.. it runs again.. but it seems that it should'nt be stopping.. since i wear it everyday.. does it need a proper cleaning?
ibewjm
Level 2:
Habit-Forming:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 105 Answers
  • Posted on Oct 08, 2018
ibewjm
Expert
Level 2:
Habit-Forming:
Cheetah:
Answers
105
Questions
0
Helped
51526
Points
169
Nail on the head. Take it to a good repair/service shop that does Rolex service. Know this, it wont be cheap. But you will get the watch back in great condition and it will run perfect.
5 Related Answers
Anonymous
  • Posted on Jan 05, 2009
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
unscrew the winding pin until it opens to the first position. (this position is for self winding. approx 30 turns clockwise will fully wind the watch)pull pin to the next position. this sets the date if it is a quickset. 1985 to present. again turn clockwise to the desired date is present. pull the pin to the final position and this will set the time turning clockwise as well. hope this helps.
Anonymous
  • 26 Answers
  • Posted on Jan 06, 2009
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 04, 2009
SOURCE: does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Anonymous
  • 183 Answers
  • Posted on Sep 18, 2009
SOURCE: how to change bezel on Rolex Datejust
The bezel is secured by a Teflon gasket. To remove the bezel I would use a watch knife and gently press it in between the bezel and the case. Make sure you go straight in and it might not be a bad idea to use a layer of plastic around the knife so it doesn't leave marks. Also, do not use a widling motion. GO STRAIGHT IN. This will also prevent damage to the case and bezel. Repeat this several times working your way around the bezel. Be sure you don't continue to apply pressure with the knife once the bezel begins to come up as you don't want to damage the Teflon seal. Once you have the bezel out you will need to replace the Teflon seal the exact same way it came off on your replacement bezel and press back into place.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 09, 2010
SOURCE: How do you open the latch on a Rolex datejust
If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
How to adjust a men's Rolex Datejust, that is very slow?
Its time for a service.
Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
I usually shake my Rolex (Datejust Oyster Perpetual) because it slides to one side, but when I shake it, the second hand sometimes stops. Once I shake it again, it begins to tick again. I have tried...
What's the question? From you description of the troubles you are having I suspect that your watch may on the outside look like a Rolex, but it certainly does not behave like one. I have never had such erratic behavior even with my much cheaper, but authentic Casios.
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
1helpful
Whirring noise inside rolex oyster
Some movement noise is ok, however it may be time for a service - Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
1helpful
Fast running how to adjust to normal movement
Rolex is mechanical timing, not really accurate. Phone watch is timed by quartz crystal and may even be corrected by atomic clock on the internet.
9helpful
How do you open the latch on a Rolex datejust watch
My rolex has stopped working its a ladys datejust
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
1helpful
It's been 3 weeks no watch whats up with eric martin in nm. is he a rp off?
I too have a problem with Eric Martin. In September 2009 I dropped off 2 Rolex watches for servicing. After repeated phone calls and emails he does not answer me.
How do i remove the bezel to my rolex datejust
RECOMENDATION:
GOTO:
R/
David
14helpful
Does anyone have a manual for a datejust rolex
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
