Question about Compaq Presario M2000 Notebook
LCD replacement Hi - my draughter has a Compac M2000 with the screen black. There is a very very dim image visiable - l think it's a replacement job though. l did buy a Ebay screen [ not arrived yet ] total top lid.... Can you tell me How difficult it is to do the replement, and can you give me some pointers so l don't wreck the whole thing ...... most apprechiated Hans
  • Anonymous Sep 15, 2008
    My monitor is extremely dim, almost black. I have read the .pdf troubleshooting manual and narrowed down the problem (by completely dissassembling the unit) to either the monitor or the motherboard. Which is cheapest to try replacing first and where can I get it?
  • semperfied Sep 15, 2008
    Novelist:
  • 125 Answers
I've done few myself its not that hard really you jsut have to have the confidence to pull bits and expect the odd loud sound to be made when u take the lid apart.
The screen will have a ribbon connector which jsut plugs directly into the motherboard and a (usually black) power connector as long as you notice where the old one plugged into you will be fine.
A few pointers when dissassembling the machine , make sure you take out all the screws even those hidden ones that mybe in the battery compartment or hiding under stickers, make sure you work on a flat surface away from carpet and static electricty , before you touch the insides of the computer discharge any static build up you have by touching metal and when replacing the screen be sure to tuck in the wires so they fit snug in the case so they dont get snagged when you shut the lid.
There are no real secrets really just use common sense and take it slow
Goodluck
Posted on Aug 19, 2008
Pink vertical line in acer aspire 4736z
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Compaq Presario M2000 Notebook
Adjusting screen brightness
If you hear the hard drive spinning and you think Windows is working but you can't see an image or a very dim image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 20, 2009 | Acer Aspire 5630 Notebook
IBM ThinkPad X31
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 30, 2009 | IBM ThinkPad X31 Notebook
Black screen on led
Monitor is going bad. Have it checked by a reputable repairperson.
Mar 28, 2009 | NEC MultiSync LCD1935NXM 19 inch LCD...
Back light or inverter. my screen is black.
Mar 28, 2009 | Dell Inspiron 8600 Notebook
Dim Screen when Power is Unpluged
Mar 27, 2009 | Dell XPS M1330 Notebook
M/c is on black screen
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
LCD backlight not working
Hi.....It would appear your backlight has "blown" (it is just a thin,long bulb in the bottom of your screen)....It will need replacing ....Although you could purchase one yourself to fit it would be best to leave this job to a service engineer
Hope this helps
May 14, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
