Question about Lexmark Office Equipment & Supplies
I just purchased a Lexmark X6570 and have two questions. First, it constantly shoots out a blank sheet of paper prior to dispersing the printed page. How can I fix that problem. Second, when printing from the internet, the printer does not indicate that a page is printing. How can I fix that? Thank you, William
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Both are a function of the page settings for either application. the printer is just doing what it's told.
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
I was instructed by Lexmark technician to pull the blank sheets of unprinted paper from the rollers which I did. After I did that, the printer stopped working. There were several pieces of paper in the...
Not sure about that, try running through a cardboard or any heavy weight paper through the rollers. Make sure it completely goes through and try the printer again.
Jun 27, 2011 | Lexmark X6570 InkJet Printer
In trying to repair my Lexus x6570 the teech over the phone hhad my pull the paper out of the rollers & then then printer stopped working. Everything was woorking fine until this incident. Are you...
I'm not sure if I understand you correctly but it sounds like you had a paper jam problem and now your printer is not functioning properly. Here are some tips:
  • Make sure to remove the paper jam completely.
  • Avoid leaving torn paper in the printer, this would cause future paper jams.
  • Unload the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and then close the printer cover. Load some paper. Try to print again.
Jun 26, 2011 | Lexmark X6570 InkJet Printer
When trying to print using my laptop "wireless printing", I can't print to my lexmark X6570. I get a blank page printed or it just says 1 document pending. It will however, let me print a test page. I am...
Is your printer setup to print "wireless"? Does it have a wireless card in it? You may need to try hooking it up to a wireless router to be able to printer from your laptop.
Jun 07, 2010 | Lexmark X6570 InkJet Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
Printing on business card stock
goto avery website and download designpro for free it has all the templates for avery stationary
Mar 18, 2009 | Lexmark X6570 InkJet Printer
Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Nov 29, 2008 | Lexmark X5150 All-In-One InkJet Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
