Question about Brother IntelliFax-2820 Laser Fax
No image cannot open front cover and we cannot get an image on our faxes or copies
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Door stuck, must open. check the latches.
check cartridge, have toner in it?
check scanning lamp ( thin strip of glass inside the machine)dirty?
Posted on Aug 21, 2008
I bought this x1240 second hand. it prints and copies well. how do i get it to fax
You will need to connect your Lexmark X1240 printer to a computer that is hooked up to a fax modem. Open the top cover. Place your document you want to fax facedown on the glass. Make sure the upper left corner of the front of the item aligns with the arrow. Close the top cover. Open the Lexmark All-In-One Center. From the Creative Tasks section of the All-In-One Main Page, click Fax an image. Follow the instructions on the computer screen. I hope this information has been helpful. Thanks.
Dec 28, 2010 | Lexmark X1240 All-In-One InkJet Printer
My copies show a vertical line down across the document.
  1. open the front cover
  2. look inside the fax you will find the scanner unit dirty
  3. umplug the machine from the power source
  4. clean softly with alcohol
Dec 06, 2010 | HP 640 Inkjet Fax Machine
Says to replace drum soon, i've bought two, and still can't make copies or receive faxes]
Perform the manual drum counter reset. Open the front door cover & keep open. Then press clear. It should say replace drum, press 1 for yes it should then say accepted. Close cover & off you go.
Good Luck and Thank You for using Fixya.
Sep 04, 2010 | Brother IntelliFAX 4100 Laser Fax
I want to receive my copies out the front not the back of the fax/copy machine.
You will need to close the back cover. The reason its comming out the back because it has been left open.
Mar 24, 2010 | Brother IntelliFAX 4100 Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
I get a partial copy when using my Sharp FO 5600
Make a copies with something with a lot of print. open top cover when the paper is 1/2 way through the machine. pull out the toner & drum unit's look at the drum is there a full image on the drum but not on the paper then it is a transfer problum. If no image on the drum then we have a laser unit problum. There is a shutter that opens when you put the drum in & closes the top cover. it may fallin out of place. hard to git at or somthing is blocking the laser beam ( paper, dust bunnyies or fourn objest ) hope this helps let me Know
C.W.H.
Jan 29, 2009 | Sharp FO 5700 Plain Paper Laser Fax
PLS OPEN COVER MESSAGE
i don't know how far you tore this down but usually this problem has to do with the black arm linkage that hooks to the left side of front door. if it appears to be hooked to door ok, then if you took all covers off you may have dislodged the linkage further back where it hooks to your laser shutter.
hth,
razors
Dec 30, 2008 | Brother IntelliFAX 5750e Laser Fax
Brother Fax 2600
open the front cover and try to see if there is any piece of foreign object blocking the imaging light
May 17, 2008 | Brother IntelliFax-2820 Laser Fax
"Offline"
which cover are you opening? You must pull open the bottom cover not the one under the keyboard. It's the bottom front cover not the top front cover.
Sep 26, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
21 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
