I presume you mean the clutch interlock switch on the pedal assembly. There is no neutral safety switch for a manual transmission. The interlock switch requires the clutch to be pressed when starting.
The switch has two 12mm (or 14mm?) nuts to adjust the position of the switch. There's a wiring harness connector so the switch and short cable can be removed.
SD
To install:
Neutral start switch and its location on the C3 and A4LD transmissions
