Question about Pioneer DEH-P80MP CD Player
Wish to install a pioneer cd/radio in a 89 honda civic
There is a harness back there but all the wires were cut. All I know for sure is that there is a black wire going to ground, and which are the speaker wire pairs. The back of the cd/radio has a couple of sockets which say 'L' and 'R' Probably go to the speakers, right?
There is a fairly thick white wire - could it be the power/hot wire?
So to start at the beginning there are no plugs to plug into the 'L' and 'R' sockets, but when I get them do they use both of the wires coming from each speaker?
Thanks for you patience
Ron.
  • Anonymous May 11, 2010
    Whats the model of the Pioneer radio?
    Regards
    DarkmanUK
What can i do to install my Ipod
Posted on Sep 29, 2008
SOURCE:
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
I have 1993 honda accord im try to swap a 2000 honda civic radio but my honda accord all we have for speakers cables are red blue green yellow and white,i can't figure it out wich one goes were the 2000...
All cars with 4 speakers have 8 speaker wires (4 positive and 4 negative). The colors of the wires for these two cars are not the same. The only way to know which wire goes where is to get wire diagrams for both cars. Before cutting up your wire harness, check that the radio you're installing will bolt into your car and fit. Just swapping the mounting bracket may not work.
Mar 12, 2011 | 1991 Honda Accord
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
I have a honda im trying to hard wire it directley with the pioneer harness everything is connected right except there is no wire for my illumination wire to connect to. also im getting no power to th
you do not need to connect the illumination wire that is to dim the radio when the lights are turned on. make sure you have +12v on both the red and yellow wire and ground to the black wire. the yellow should be unswitched and the red should be a switched source.
May 20, 2009 | Pioneer DEH-1100 CD Player
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
Mar 19, 2009 | 1986 Honda Civic
How do I know if a new/used car cd player will fit?
yes.......... just buy a mounting kit for your car and a wire harness for your car.........to install just unplug factory radio and clip the harness on to factory plugs that you just unhooked from factory radio now just attach the same colour to colour wires from your new deck to the harness......mounting kit comes with instructions
(make sure to buy WIRE HARNESS & MOUNTING KIT for your car) and your install should take less than a hr to do
have fun
Feb 18, 2009 | Pioneer DEH-P2000 CD Player
Dehp5800mp wire harness
orange /white wire is power antenna wire i think.is your setup working????????.let me know the status..
Jan 06, 2009 | Pioneer DEH-P5800MP CD Player
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
Got a new deh-6000ub and wire harness for honda accord dont know how to install the harness
You need an installation harness. You can get them at most anyplace that installs car stereos. Once you have the installation harness for your car, you just match up the colros of the wires on it to the same colors of the harness for the Pioneer. Make sure that each wire is insulated from anything by using some electrical tape and make sure they all have good connections. Strip away close to about an inch on each wire and then twist them together and then tape them good. After all the wires have been connected, all you need to do is plug the Pioneer harness into the Pioneer radio and then plug the installation harness into the factory wire harnees connector in the car. If you have any wires that do not match up in color, you can normally leave then not connected to anything, but make sure they are insulalted with electrical tape. Most all the wires should say what they are for. Matching the colors is the easiest way to do this.
Let me know if you need more help. I can always give you a detailed wiring of the Pioneer. I do not have the wiring diagrams for the car though.
Jul 20, 2008 | Pioneer Car Audio & Video
Wiring/Installation of Pioneer CD Player
You need to get an installation kit that also has the universal wiring harness to connect to the factory harness in the car. That way you only need to match the wire colors of the Pioneer harness to the wire colors of the universal harness and made good connections and insulate those connections. Then the Pioneer harness plugs into the Pioneer radio and the universal harness plugs into the factory harness in the car.
Let me know if this helps, or if you need more help.
Dave
Jul 06, 2008 | Car Audio & Video
Pioneer DEH-P80MP CD Player Logo
260 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
