Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-Air JFI2589AEP Three door jenn aire just installed. Water seeping out from under the unit. About 1/2 cup or so. I've found it twice. I don't think it is continual. Not pouring just seeping. The unit has been running for about 30 hours total and the freezer drawer is frosty this evening for the first time. Do you have any idea what the problem might be? Thank you.
  • 943 Answers
Hi thanks for the question if your getting water now 2or 3 times the drain hose going from the freezer to the drip tray under neath is clogged also the drain hose may not be in its proper place in tray possibly when it was delivered remove back panel behind fridge and locate drain hose and re install in proper place in the pan thanks the appliance doc
Posted on Sep 17, 2008
#JFI2589AEP freezer temp too high
You might try pulling the refrigerator out and vacuuming the coils in the back of the appliance. Check that you have clearance all the way around the unit so that air can get to the fans. You may need a new thermostat, but hopefully cleaning will do the trick. Check the manual for troubleshooting help before you call a repairman. (Manuals are available online if you have misplaced it.)
Jul 27, 2013 | Jenn-Air JFC2089HE French Door...
Jennair jsp42ppdbda faulty evaporator drip pan - leaking down into freezer compartment
I've got the same problem. After installing a replacement drip pan (W1019913) and disconnecting the thermistor per the enclosed instructions, the problem returned within two months. I just called Jenn-Air customer service and was told that there is a new design for the drip pan this is only available through Jenn-Air, and not through distributors. Therefore the part I purchased in November through a distributor was the old design (even though it was dated 1/27/11).
The Jenn-Air rep agreed to have a tech install the new design under warranty, even though I purchased the unit almost 5 years ago. I'm hopeful that this will correct the problem.
If you still want instructions on how to remove the drip pan, let me know. But I would return the part you've got and ask Jenn-Air do it for free.
Dec 14, 2011 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air JFC2290v water appears on the floor front right corner, sometimes front left corner as well. I have moved the unit and have not found any water under it. This has been on going for...
I bought the same JFC2290 model and it says "Auto defrost". Mine is only 10 months old and it starts having exactly same problem already. Water leaks and I have to clean my hardwood floor twice a week. I will never own Jen junk again!
Nov 09, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
How do i locate and replace a dual water valve on a jenn air jfi2589aep french frig ?
The dual water valves is located in the back of the refrigerator. You will have to remove the panel in the back of the fridge in order to access them. Use wire markers to mark the connectors to identify which commector goes where after replacing the valves.
Dec 15, 2010 | Jenn-Air JFC2089HTB French Door...
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Dec 24, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JCD2389G Side by Side Refrigerator Logo
170 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
