Question about Sony KP-48V90 TV
No picture and tv automatically turns off
When you turn the tv on you get a dark screen with lines running through it and after a few seconds the tv just turns off. You can't adjust anything or see a picture at all. The standby light blinks the entire time but it isn't just one number. Sometimes it blinks 4 times sometimes 6. When the TV comes on, the picture is fine ... all colors are normal. Then, after about 15 to 20 seconds, it turns off ... yet the audio remains. The screen does not go completely black but one can see a faint diagonal "signal" on screen. I'm going to unplug the TV for about a day and see what happens. I don't know if it's a thermal problem of a component or if the system needs a re-initialization.
  • 129 Answers
Good day.
You are getting an intermittent performance for your unit. One reason for this might be with the loose contacts on the high voltage section of your unit. Have it resoldered.
Regards,
chris
Posted on Aug 19, 2008
6ya staff
SOURCE:
Vertical Bars Horizontal Lines on LED TV
Check the input connections. If Ariel connection, or other video input connection from any external source have loose contact, or wire broken, this type of interference can occur to picture.
Gopakumar Gopalan Google
Apr 23, 2014 | Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Picture suddenly turned dark
hi the picture tube of ur tv has got damaged and it badly needs a replacement.. so its better to replace ur picture tube..
thank u rate me!!
Feb 08, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sansui Projection TV - RCA D52W23 52 in., Problem is tv gets turn off automatically after few minutes. It doesnot off but a blue screen with lines appears immd.., it takes long time get the picture on...
CK for Bad capacitors cp114,120,150 if any of them is puffed up on top it is bad so replace all 3 cp150 is 2200uf 16v other two are 220uf 35v also resolder all pinns on FBT flyback transfomer.
Jan 23, 2009 | RCA D52W23 52" HDTV CRT TV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
[email protected]
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
Picture problem
Usually that symptom is caused by cracked solder joints on the vertical output IC. As the IC starts heating up, the picture starts breaking up at the top with several "dancing" dark lines appearing, the top scrunches down and then when the vertical quits altogether, the screen goes completely black. A good slap on the side of the TV might make it happen faster or clear it up temporarily. If you have experience working on PC boards then you can resolder the pins of the vertical output IC but if you have never soldered parts on PC boards then allow a qualified tech to handle it for you.
Nov 20, 2006 | Sony KV-35S42 35" TV
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Sony KP-48V90 TV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
