Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Standby mode and can't get tv to work
Been into menu and turned off all timers
tv goes into standby and cant get it back on
  • 4,234 Answers
This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
Posted on Aug 19, 2008
LCD TV goes off on its own
it must probably has a sleep timer set on the menu which means if the channel is not changed over or the tv doesnt acknowledge that it is being watched it switches off to standby mode - check your settings
Jan 23, 2012 | Televison & Video
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
I have a 2 year old Vizio P50HDTV20A 50 in. HDTV Plasma TV Occasionally, when I turn it off, it goes into standby mode as normal but then will not turn back on with the remote or the power button on...
i think you unconciously program the tv on its timer mode and it is still not yet remove. check it out on menu, find the time set it off. if you already done it then the system i.c. has the problem
Jan 28, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
How do i set the timer? i use it for my alarm.
Which timer do you want to use? To use the On/Off Timer, press Menu and use the navigation arrows to select Time. Press Enter and navigate (up/down arrows) to select either On Time or Off Time. Press Enter and then use the up/dwon arrows to select Repeat. Select the frequency for the timer function (off, once, everyday etc.) with the left/right arrows. Use both the up/down and left/right arrows to set the time (hour or minute). Press Return to return to the previous menu and Menu to leave the OSD menus. For the On Time, you can also select the input source that will be shown when the TV comes on. (Select Input similarly to the above directions and set the desired channel if the source is TV.) The time must be for this to work (select Time and then Clock then Auto (gets the time from a digital channel) or Manual) and the TV must be in Standby mode for the On Timer to work. The TV will go into standby in two hours after coming on unless a button is pressed on the remote or the TV. The Off timer will override the TV On if they are set for the same time.
The Sleep timer is set in the same Time area or in the (from the remote). Select Sleep time and then the length of time you want the tv to stay on before going to sleep. This is reset when the TV goes off.
The Shut-off time is set in the Time menu as well; select Auto Sleep. When this is on (on/off options), the TV will shut off after 10 minutes without a signal.
I hope this helps.
(you will have to reset the timer after a power failure)
Oct 06, 2010 | LG 32LG30 32 in. LCD HDTV
The tv starts to come on,then goes of and the
off the sleep,standby timer mode on your TV.. you just check all the timer then turn it off.
Mar 27, 2010 | Televison & Video
Power turns to standby
Go into the menu and change to setting for the timers and power settings.
Nov 20, 2009 | Televison & Video
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Standby/timer light
check your menu settings to see if your off timer is activated or set.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
