Bosch 24 in. SHU43 Built-in Dishwasher Logo
Posted on Aug 19, 2008
Bosch SHV 4303 Dishwasher not draining
Gary David
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Aug 19, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2665
Points
21
Change your water pump or belt . Also make sure that no one just changed the garbage disposal and did not take the plug out of the disposal housing before installing the washer drain.
Good Luck
TEETERMAN
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
tip
Bosch DIshwasher Woes
Does you Bosch dishwasher seem to hang up at finishing the dish washing cycle?<br><br>Since originally writing this tip 2-3 years ago (2009 maybe?), I have provided the upgrade to countless others who have had the problem. Here it is, 2013, and I continue to upgrade several control son a weekly basis. Please follow the information below, and I can assure you that your dishwasher will be up and running again - better than new!<br><br>I happen to own one of these beauties, and SHU4306, and while all the Bosch dishwashers in this series of dishwashers do an excellent job of washing the dishes, they also have a design flaw that is very expensive to fix as it requires a new controller board.<br><br>But the problem surfaced with our dishwasher a few months ago, and I was put to the test by the resident dishwasher at out house, who is not happy when the dishwasher is broken.<br><br>There is a relay on the controller board that will fail, sooner or later. Bosch even has a service bulletin for their techs on a recommended procedure to repair a burned place on the circuit board underneath the relay. However, the repair is short term, and eventually the relay will fail again (I know, I tried it.). The repair is not sufficient, and there really is a more economical, and more technically correct, way to repair the board.<br><br>After the Bosch directed repair failed, I pulled off my dufus cap, put on my Engineering cap, and dug in. Here, I found the failed relay, and discovered the flaw in the board design. I ordered a more substantial replacement, and two days later, I was up and running.<br><br>I know that the failure occurs on the following Models-<br><br>SHI<br><br>4302 4306<br><br>6802 6805 6806<br><br>SHU<br><br>3032 3035 3036<br><br>3302 3305 3306 3322 3326 3336<br><br>4302 4306 4312 4316 4322 4326<br><br>5302 5304 5305 5306 5307 5312 5314 5315 5316 5317<br><br>6802 6805 6806<br><br>9902 9905 9906 9912 9915 9916 9922 9925 9926<br><br>SHV<br><br>4303 4803<br><br>There may be others, and, other manufacturers may have similar issues.<br><br>Bosch also provides a test sequence for their dishwashers that anyone can put the dishwasher through to help isolate what the problem might be. I am sure other dishwasher manufacturers do the same, and I will continue to dig for those sequences as time permits.<br><br>Contact me for additional help and support in determining the cause of your failure, and instruction on what parts to purchase or what to do next. (Don't throw the dishwasher out with the dishwater, so to speak!.).<br><br>You can reach me at - BoschRepair "at" tx.rr.com - (type it in as an email address, just like it sounds :-) ).<br><br>I can also make repairs to failed boards, where I make the needed repairs and test the board on a test bench made up of the same components that are found in the dishwasher. I do this with quick turn around, normally shipping the boards out the same day I receive them.<br>All repairs are made taking into consideration my years of experience in HVAC and appliance repairs, including working as an Engineer in design of such equipment, working with listing agencies such as U/L and CSA. I know what the concerns are, and will only make repairs that I deem are suitable and equally if not more safe than the original design.<br><br>I can easily save you the cost of a new board, as my repairs are 1/4 the cost of a new board.<br><br>Looking forward to hearing from you!<br>
on Dec 18, 2009 • Dishwashers
Bosch dishwasher time delay problems
Bosch Dishwasher Repair
When the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here
The problem is that the circuit board copper is not heavy enough to handle the heating element current, causing the copper to heat and melt the solder connection. A better solution is to solder a short length of copper wire between the two pins to provide more copper and reduce the chance of heating as shown in the attached photo.
5helpful
2answers
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
• If the display blinks with a "0", you will hear
no signal (indicates OFF).
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Dear Sirs, I have a client with a Bosch dishwasher that is leaving a film on all of the dishes. the water valve is working and the drain pump is working. Apparently this has just started. Any ideas?...
Hello
Welcome to FixYa.
Can you provide a model number of your Bosch dishwasher ?
Depending on the model ( i.e. SHU, SHV, SHE, SHX followed by several caricatures etc. ) it can be several possibilities so I`ll hold off generalizing and instead try and speak specific about your model.
Regards,
Macmarkus :)
How do you install a custom panel onto a bosch SHV
call bosch. There are specific instructions and a template they supply for measuring and attaching the panel. But that's all I can offer. Understanding the instructions is a whole 'nother' problem.
Non return valve
Has it always done this? If so it was an install issue. The tech should have put the drain above the drain with a loop to prevent backfill.
Jan 26, 2009 • Dishwashers
I have a Bosch Classixx with what sounds the same problem.It would not drain properly and hummed even when the front door was opened.After a couple of days it ponged a bit.This is what I did.Sypnoned off yukky water with a short length of hose (fill pipe with water from tap don't **** on it!!).Cleaned filter under cutlery tray at bottom.Then put a TEASPOON of bleach if on main drainage or dishwasher cleaner if septic tank.Ran on a hot wash and see if it sorted problem-it didn't but did clean system.
Syphoned off again -take care.Isolated electric and water supply.-Should do that first perhaps Pulled out from under counter undid drain hose at sink end and water at machine end.I then put machine on side and undid bottom silver plate.Note position of polystyrene float switch cover.I then followed drain hose to drain pump and undid it by twisting it like a bayonet light bulb undoing clip levering with screwdriver (not for feint hearted as easy to break) -I then checked little impeller for foreign object-found none so pulled off pump housing by rubber hose to bigger pump thing next to it and found small bit of plastic put it back together and hey presto problem sorted-I was told it might take two hours for the expert to do it once on his workhop bench-it took me about 30 mins plus a bit of head scratching and a yank and push or two which could have been rather expensive -I was lucky!
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
