Question about HP OfficeJet D135 All-In-One InkJet Printer
Printing Problem When I print I get empty lines of no color. I have tried to clean the print heads but after the first print it goes back.
  • 48 Answers
Posted on Aug 19, 2008
The ink is blurred and not printing all the colors
Hi, You could try cleaning the print heads with a damp paper towel. Gently dab at them until you see clear colors with no bleed. It's ok even to let the damp paper set on head for few minutes. Also clean the print area in printer. Then put cartridges back in printer and run a print head cleaning. You may have to run it a couple times.
this has worked for me unless of course a cartridge is empty of a color.
Good Luck to you, I know you can do it,
tina
Mar 26, 2014 | Kodak ESP C315 Wireless All-in-One Printer
Canon i350 does not print all colors
HI,
Hope this will give you hints. To pin point directly you need to replace printer head. But before replacing please consider suction cartridge caps or nozzle by cleaning and freeing clogged airways by dettaching manually. I understand that the long time being not used has caused the problem. However if you can still use black and other colors then used it than complicating downtime in repairing procedures. Yes, you are right no need to clean deeper more than three times it will consume inks half empty. Have a nice day.
Please don't forget to rate the solution..
Apr 07, 2008 | Canon i350 InkJet Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Lines thru photos
Try to clean the nozzles with the printer troubleshooter. It will force all the nozzles to print at maximum quality and will clean the clogged nozzles. If the procedure fail, then try again. This happens when you are not using the printer for long periods of time. If cleaning nozzles will not be helpful, then remove the color cartridge from his place and put it with the printing head in warm distilled water for 30 minutes.When the water is coloured by the ink, take the cartridge and touch the printing head with a soft paper towell. If a clear line of colour is printed on the towell, then is OK, put it back in the printer and print a test page. If is not , try again with patience.
Apr 14, 2009 | Office Equipment & Supplies
Mp370 nnot printing color even after changing ink tank
take out both ink cartridges, lift up head clip and take out printhead block
stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
do a clean cycle
Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
I have a Canon S400 series printer and I can't get it to print anything at all. It goes throuh the motions of printing but it doesn't put any thing on the paper but a few small colored lines. Is there a...
FIRST YOU CHECK WEATHER YOUR CARTRIDGES ARE EMPTY OR NOT.IF EMPTY REPLACE IT. IN YOUR PRINTER PROPERTIES DEEP CLEANING OPTIONS IS THERE, BY THIS DEEP CLEANING YOU CAN CLEAN YOUR PRINT HEAD NOZZLES. IF IT IS NOT CLEARED REPLACE YOUR ENTIRE HEAD UNIT.EVERYTIME , USE ONLY GENUINE CANON CARTRIDGES .
May 04, 2008 | Office Equipment & Supplies
Mp 360
I had exaclty same problem - black not printing - was about to buy a new printer but did the following as a last resort about a month ago - remove the ink cartridges - removed the head and sat it on an a tissue - into the 'well' where the printer cartridges sit I dropped into there a very small amount of water as if to 'wash it through' where the ink would flow, (about a quarter tea spoon) - agitated it a bit - this flushed thru the gaps were the ink goes - I cleaned it all up - dried it with a tissue - put it all back together - it works fine now ! This was a last resort option for me but I guarantee it did work !
Oct 11, 2007 | Canon MultiPASS MP360 All-In-One InkJet...
Canon Lines in picture and colored word doc
you should check whether the color ink is out or not. If so replace it with a new one. Otherwise just cleaning the print head will solve your problem. To clean the head Go to control panel > open printers and faxes > right click printer icon > Click properties > Find the option "Clean print head" or somthing sismilar. Use it and your problem could be solved. Note: Some printers have seperate software utilities to clean the print head.
Sep 11, 2007 | Canon Pixma iP6600D InkJet Photo Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
