Question about Orion1934 19" TV
1934 model recieving
What a ir detector
    Genius:
  • 1,139 Answers
Cthy_prry,
The IR detector is in your TV set. It is the device that picks up or captures the IR signal from your remote control and turns it into an electrical signal that the TV via a processor interprets as a function or command to have the TV perform in a certain way as turning on, channel up or down, volume up or down, etc.
IR means Infrared
I hope this answers your question.
Thank you,
Shuttle83
Posted on Aug 23, 2008
SOURCE:
Recieve is garbled sounds like donald duck
Sounds like the audio driver input is being over driven causing distorted voice, regardless of the volume output. Either that or possibly the detector is incorrectly tuned to strip the audio from the carrier wave. Depending on the model both might have adjustments. My bet would be on the detector.
May 22, 2014 | Radio Communications
FS-4DA coin sorter won't count pennies
The good news is that the unit is functioning, it's just counting pennies. I had the same problem with quarters and is a fairly easy fix. I won't get into any disassembly details, but you'll need to gain access to the infrared detectors (mounted to the motor assembly) and possibly the emitters (mounted to the front panel LCD display/push button board). Also, please be careful not the damage the wire harnesses when removing the top cover. Once apart, you can use your cell phone camera (which is sensitive to infrared) to see a purplish/white glow from a healthy emitter. Compare the penny emitter to the others and chances are it will have a lower output level and need replacing. If the penny emitter is strong, then check the detector with any infrared remote control( TV, cable box...) by pointing the IR remote control towards the penny detector and pushing any of its control buttons. This should make the penny amount count up, and fast too, as the remote sends out IR pulses while a button is being pushed. If this test doesn't increment the penny count, then the penny detector needs replacing. But before you do, try this remote control test on another known good detector to verify your findings. Please keep in mind that other malfunctions besides an emitter and detector could be the cause of your problem, but given the FS-4DA circuitry, the odds are extremely high that you have a bad emitter 1st, then a detector 2nd, as emitters are known to degrade over time and especially when continuously powered, as in the case of a switched 'ON' FS-4DA. FYI...IR emitters and detectors can be purchased from Radio Shack. Good luck and take care not to electrocute yourself when powering the unit with its cover removed.
Feb 21, 2014 | Royal Sovereign Fs 4DA Model Fs 4DA Coin...
Replacement part for Bose Cinemate Interface
Replacement parts for Bose Cinemate Interface can be foudn at amazon, take a look here: Amazon com Bose Cinemate parts. I hope this helped. Cheers
Oct 29, 2011 | Bose Cinemate Digital Home Theater System...
I think the infrared reciever in the TV isn't picking up the remotes signal It won't go on standby or put sound up or down etc I have a Thomson TV/DVD 17 inch .
Make sure that the remote is working by pointing your remote to a IR sensor or use the phone camera to detect -- open the phone camera/digital camera and show the remote with button pressed on to the camera as it will be displayed if IR works.
If so then the IR detector in the TV must be taken out , checked and replaced. You can measure the incident voltage on the IR sensor in the TV if present but not sensing it is faulty but if working without any action then the processor is also a suspect.
Mar 17, 2011 | Thomson Televison & Video
Goes off only at night with NO warning cleaned & changed batt. 4 times so far !!!!
These types of smoke detectors are PHOTOELECTRIC, the way it works, there is a IR transmitter and a IR receiver placed in a dark chamber aligned at a 45degree angle, when smoke enters the chamber IR light bounces of the smoke and than generating an alarm, so in conclusion if there is a lot of DUST in the chamber it reflects the IR light just like smoke, than can generate an alarm, try blowing air in the smoke detector (gentely) if it does not work replace the smoke detector...
Feb 04, 2011 | System Sensor 2100rfadt Wireless Smoke...
I have a Westinghouse model SK-26H520S tv that has started turning on at odd hours of the night and day. All timers are set at "0".
The IR preamp could be acting out, or some one else has a westinghouse tv and could be close enough to yours and creating the problem. The easiest thing to try first is to cover the IR reciever window and use it manually for a few days, if the TV still does its thing then you'll have to replace the IR reciever, it's usually located on the key board panel(vol,chnl,pow keys) or just replace the keyboard panel if it's available. Try the partstore.com, they usually have parts availability and price information
Mar 16, 2010 | Televison & Video
Our Philips remote lost its signal to the TV. Dont have the instruction to look up code or how to progam it
dkellogg246, Try the philips website to see if u can download the instruction book or check with local repair shop to see if it even emits any infrared light out of the IR emitter diode!! How many times has it hit the hardwood floor? could be the battery contacts are in bad shape. I'm lucky I have what is known as a hand held IR scope to test output of remotes. But they cost 20 times more than a remote. Let me know what u find out. Kodak used to sell a "IR light sensitive card" detector that would glow pink when IR light hit it. But this "business card" size sheet of detector paper cost $40.00. Good luck! Hope this helped.
lmistyrel @aol.com
Sep 16, 2009 | GE Televison & Video
I need the manual for the cobra esd 767 i did not recieve one
Go to www.cobra.com select U.S. then support then radar detectors and your model is the first one. Right now downloads are "off line" their doing updates to their system. but they say it will be back up soon. Hope this helps
Jun 24, 2009 | Vehicle Parts & Accessories
IR detector
An infared detector is just a transistor that is covered with clear plastic.
matching the spec on it though is hit or miss.
first be sure it is not the ir trasmitter, take it to radio shack and see if their infared re-transmitter broadcaster sees it . or aim at a digital camera
or hold near a radio though that only hears the digital part.
radio shack has some iR transistors in stock usually .
basically you can just plug one in and it may work but you may have to know how to bias (balance ) the transistor to work correctly.
there are many places to scrounge a ir receiver transistor
old tvs , learning remotes, laptops , printers ,
you can inject the output signal of the remote into the ir circuit to see if it is working but you need to add a resistor and drop the voltage a bit.
hope that helps some.
Apr 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
Orion1934 19" TV Logo
65 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
