Question about GE Spectra JBP78 Electric Kitchen Range
Everything quit at once.
We were cooking dinner and were using 3 burners and the oven, when it all stopped working. Any suggestions to the problem? And no Its not a breaker.
  • northten Sep 22, 2008
    After self cleaning (which seemed to work fine) my wife was wiping down the oven and heard a pop. Everything is now out. No power to anything. Is it fried? The unit is less than ten years old and we did have a problem once before of the heating element sparking and had to replace it.
  • 1,543 Answers
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. (Assuming your 50 Amp breaker for your range did not trip and you have power to everything else in your home) Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker
Posted on Aug 31, 2008
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
Nov 25, 2014 | Emerson MW8119SB Microwave Oven
I was cooking dinner. Was using Kenmore oven on Broil and heard a loud pop. Everything went dead. Is my oven dead? Can it be fixed and how much would it cost? Would it be better to buy a new oven?
they dont make em like they used to anymore.. be looking under the top for a burnt wire somewhere..if the burners still work its ok if they dont. check your fusebox.. see if a fuse blew..
Mar 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
I'm in the middle of cooking dinner and I got a f3 e2 error and the oven locked...how do I get my dinner out? My husband is an elevator mechanic so he's handy...we turned off the breaker to quit...
That code refers to the oven temperature sensor sensing a too hot oven. I suspect what you did to quite the cleaning cycle should help once the temperature cools down the door should open. I am a little confused, did you set the oven to clean while your cooking, or did it do this on its own, or was it preset and yopu forgot it was set to clean? Your temp sensor may be going bad if it just detected a too hot oven while your cooking. If it started cleaning then it may have gotten too hot and this is the safety device to prevent it from overheating. it sounds like it is trying to self clean, its essential that you find the error code sheet, stuck in the stove or oven cabinet somewhere, also check your range settings so that it is not set to auto clean.
Jun 28, 2011 | Ovens
Kitchen aid sparking on all burners
one of the burner switches is shorted, take off plate that covers the switches and remove the wires one at a time on each switch then reattach wire before going on to next switch.continue until sparking stops,replace switch (easy fix)
Sep 08, 2009 | KitchenAid Kitchen Ranges
All my burners arnt working! HELP!!!
There is a cooktop PCB (power control board) which is separate from the oven. Perhaps that is the problem. That board is located behind the cooktop control membrane panel.
Oct 24, 2008 | LG LRE30755 Electric Kitchen Range
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Burners Blew
if you will send me your model number off your serial plate on your range will be on front open oven door or lower drawer some where and when you bought it i need to check the service bulletins before i reply but dont rate me till were done
Jan 02, 2008 | KitchenAid KESC300 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
