Question about Sanyo HT32744 32" TV
Sanyo TV - HT32744
Hi --
I have a 32" Sanyo TV that I purchased in May 2005.
My problem is with the color. The reds, blues, yellows and greens are like neon -- very, very bright -- and it is hard to get any definition. I tried manually changing the color, unplugging the TV for an hour, and pressing Reset, but nothing seems to help. Do you have any ideas?
Thank you very much.
Susie
Lower the contrast first.
If colors not in balance, reduce saturation until "normal" to your eye with whichever color (or color pair) out of balance.
Posted on Sep 08, 2008
SOURCE:
Have a Sanyo big screen tv but need need to adjust the color, to yellow!
Need to know if older set with picture tubes---turn color off--if yellow screen you have a loss of blue of some sort--red and green will give you a yellow screen. If set has the 3 picture tubes look inside in the lens to see if all 3 have a image---little or no blue means a problem there.
Oct 15, 2012 | Sanyo Televison & Video
All the colors for all programs are blue and yellow on tv. have tried all the picture settings but nothing changes.
hi" do you try to adjust color settings.theres a red,blue,green color adjustment under picture setting.
try to set red color to full.
of you already do that.
probably your display driver board has a causes the problem.
display driver board produce image comes from the tuner, then it sent to x and y drive of your LCD screen.
Aug 30, 2011 | Sanyo DP26647 26 in. LCD TV
Model #
The solder joints on the CRT board might have cracked and cause this symptom. What you are describing indicates that the red gun is intermitten, and the solder joints on the CRT socket itself (red cathode) or the red output transistor have probably cracked loose.
Aug 23, 2008 | Sanyo HT32744 32" TV
TV problem
Sound like either the Red or Blue driver transistor on the CRT board is intermittant.
Hope that helps...
Geno
Apr 03, 2008 | Televison & Video
Black pic on tv turns green
normally this means the high voltage preamp green control transistor on the neck of the tube circuit board is loose solder connection from heat or is going bad.
Feb 17, 2008 | Sanyo HT32744 32" TV
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
Sony kv-36xbr400
hi there, check-up the CRT board circuit. a video section problem, there maybe an electronic part defective. do some test and see any cold solder or loose connection on the crt board circuit. ty
Nov 15, 2007 | Sanyo HT32744 32" TV
Missing colors on screen
if you have H/D one of your cables might be loose red/green/blue  i suspact red
Oct 21, 2007 | Toshiba 32WLT58 32 in. LCD Television
Sanyo HT32744 Picture mostly green and blue
On mine I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Jun 22, 2007 | Sanyo HT32744 32" TV
Sanyo HT32744 32" TV Logo
285 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
