I tripped over the coaxial cable which ripped the cable connection port out of the back of my RCA 27" tv. is there anything i can do?
  • mambyj Aug 19, 2008
    Bemur,
    Thank you for trying to help. I apologize for not being more clear.I unintentionally gave the impression that my cable was destroyed. This is not the case. The cable is fine. It's the receptacle on the television itself that I ripped out. That part is still screwed onto the cable. I unscrewed whatever you call this part and tried to reattach it to the tv. This is why I wondered if there is anything I can do. Hope I described my problem a little better. Thank you again for your assistance.
  • 4,234 Answers
This can be repaired easily by a repair shop. I have done over 100 of these. The connector itself runs about $2-$4 and nneds to be reconnected into the tuner box. The only possible problem is that when the old one was torn out, the PC board may have been damaged. While this is rare, if the board has been broken, the only remedy is to replace the entire tuner.
Dan
Posted on Aug 28, 2008
    Brigadier General:
  • 6,966 Answers
Chances are that the cable was ripped off the connector. This is relatively easy to do but assuming that you have not done this before directions would be needed. Pls see this link for step by step instructions. Of course you would need to remove the connector at the back of the TV and see if you can still use that or purchase a replacement from any electronics parts store.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
  • Louie  Role
    Louie Role Aug 19, 2008
    Appreciate the postback/comment.
    I believe I have a better idea now of your concern. At the end of the connector (the one at the back of the TV) would be a smaller version of the coaxial cable. This would also have a center conductor/wire with a braided shield/ground wire. In turn this cable normally leads to the tuner block. If the cable was severed, then it would be necessary to reconnect them using a soldering iron. Alternately, such a pigtail (connector with wire/cable & ends with another type of connector) maybe available from electronic parts store or even your friendly neighborhood electronic repair shops.
    Cheers.
How to connect old vcr-plus to emerson tv
If the TV has RCA jacks on the back, use the red, white and yellow ports on the VCR to connect to the same colors on the TV.
Dec 18, 2014 | Emerson Televison & Video
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
TV TURNS ON AND OFF
My experience with the RCA F27242GY 27" TV going on and off is as follows:
Where the coaxial cable connects at rear and the base of the TV chassis part # 15062-57A is loose.
Mar 20, 2009 | RCA F27242GY 27" TV
Want to hook up Zenith converter box with RCA F25432 TV
Generally you just use either the F port (used often for cable or coaxial connections) or the RCA (composite) inputs.
Jan 05, 2009 | Zenith C27A24T 27" TV
Connecting VCR to TV
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
Aug 30, 2008 | Toshiba 27DF46 27" TV
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
