Question about LG Goldstar GWHD5000 wall/window Air Conditioner
There is what looks like condensation blowing in through the vents
    New Friend:
  • 49 Answers
Check your drain port, it may be plugged up
Posted on Jun 09, 2011
SOURCE:
Why does it just blow cold air?
it blows cold air because the flame hasnt ignited. You are having an ignition problem due to either an unsatisfied pressure swith and a burned igniter. Have a look in the burner ports for the entire cycle and look to see if you can see e bright orange glow. if you dont see it, check your venting for blockage and also maybe the condensate drain tube for blockage
Mar 24, 2016 | Duraflame Portable Tower Electric Heater
The condensation is blowing out the side vents. Looked through vents and saw a lot of water inside.
You have got to get that sloped a tiny bit to the rear so the condensate can get to the drain hole, you also may have to clear drain hole in pan
Jun 26, 2011 | Whirlpool Heating & Cooling
My ac in my dodge truck only works when I am driving, but when I come to a stop it will stop blowing?
Stop blowing cool or stop blowing anr air through the vents??? If it stops blowing cool air, check if the condenser fan is running (it should be)( on drivers side under hood, looks like a small radiator) if not take a water hose and deluge the condenser with water, if it then cools, you will need a new condenser fan assembly.
Aug 30, 2010 | 2005 Dodge Ram 1500
Not blowing cold air
Air vents may be blocked or your system needs to be recharged with refrigerant.
Aug 15, 2010 | 2001 Kia Sportage
I have an American Sandard 15 Sheer 4 ton unit in the attic in South Louisiana. The a/c drain line from the unit is sweating all the way to the riser vent and down the riser into my wall. It appears that...
First, air should not be blowing through the trap. The trap is there to isolate the air and to make sure condensate flow is proper. Start by increasing the depth of the trap. The condensate is going to be relatively cold, in the range of 58 degerees F to the Attic's OH MY GOSH hot. Pick up some foam insulation at your favorite hardware or Big Box lumber yard and insulate the pipe.
Jul 19, 2010 | American Standard Heating & Cooling
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
The vent for a/c is blowing out of defroster vent. not able to make it come from dash vents
Look under the hood near the condenser. There is a vacuum hose that usually breaks over time. try to put it as closely as you can back into place and place electrical or duct tape around where the air is leaking.
SJV
Jul 16, 2009 | 1999 Dodge Durango
Blower will not switch to defrost,floor,just vent,no heater
You did check for vacuum lines off, or wiring harnesses not plugged in all the way, or at all didn't you? Did you pay someone to do this, or do it yourself, because if you paid someone, have them look at all the connections .
Nov 23, 2008 | 1998 Dodge Caravan
Every winter water drips from my bathroom ceiling mounted extractor fan, worse when there is bad condensation. The vent goes straight up and up through the loft space and out of the roof, there appears to...
condensation is created by 2 exteme temperature change.
looks like the loft space is colder than the rest of the house.
first make sure there is not blockage in the vent. then warp the vent with fiberglass as much as you can. it doesn't matter what R value the fiberglass is. just enough to cut the temperture change.
you still going to need a exhust fan in the bathroom.
Oct 31, 2008 | Hampton Bay 24002 Ceiling Fan
LG Goldstar GWHD5000 wall/window Air Conditioner Logo
69 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
