Question about Mitsubishi WS-55809 55" Rear Projection Television
Ws 55809 color
The red and the blue will not come together.
  • 2 more comments
  • richless Aug 19, 2008
    I did nothing yet.
    when i try to adjust,it will not move red over to line up.
    This what i wanted to know.THANKS
  • richless Aug 20, 2008
    I ordered one. THANKS again!!
  • Mitsubishi Master
  • 13,433 Answers
So you are still haveing the convergence issue with your tv, the convergence ic chips need to be replaced to correct this problem you can't adjust it as the components are failing.
Posted on Aug 19, 2008
My mitsubishi ws-55809 works fine but the screen turns pink and after a while it goes back to perfect color. Does this back and forth
Someone with moderate experience would have to examine the red crt printed circuit board--I have seen some of these that develop a cracked ground path on that board but usually it is pink except on the sides depending which ground path is bad.
Oct 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The blue red and green lights are not aligned causing ghosts of color
Sounds like a convergeance board has gone bad, common on these projection T.V's the IC's are around 100 bucks and shop can do it for you for around 400 to 500 dollars
Oct 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Convergence issues
You will find more info for identifing the ICs needed to fix your TV from the following link
http://www.fixya.com/support/r1122465-mitsubishi_convergence_ic_part_number
Aug 06, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 needs new red tube
you can get a red mitsubishi tube at the following link and it comes with free shipping. If youre not sure which one to order, leave them a email and they will respond quickly, just let them know your model number and what youre needing. they are listed under the projection CRT catagory on the left side of their page. Here's the link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 Color
Does the neck of the tube glow? If not you may have a bad solder connection on the Red CRT PC board or a bad transistor on the red PC board
May 20, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Picture problem
start checking caps w esr meter probally leakey cap or solder conn.
Apr 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 15, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
