Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the power supply on my Westinhouse LTV-32W1 flat panel TV. What is the Part number and where can i buy it?
TV Doctor
Level 3:
  • Master 373 Answers
  • Posted on Jun 09, 2011
TV Doctor
Master
Level 3:
Answers
373
Questions
Helped
92969
Points
1011
Go to Ebay and type in the model number in the search and scroll down to reveal the availibility and price. Shopjimmy.com may have one too. Be sure to match up the number from your board.
Testimonial: "confirms what I have researched, Thanks"
Power Payless
Level 1:
  • Contributor 25 Answers
  • Posted on May 04, 2012
Power Payless
Contributor
Level 1:
Answers
25
Questions
Helped
33429
Points
51
There is a store selling those adapter for westinghouse:
http://www.powerpayless.com/catalogsearch/result/?q=westinghouse
3helpful
I have a westinhouse LTV-32W1 the screen goes
It is caused by a failing transistor that after it reaches critical heat it caused the fail safe circuit to be invoked. TV shuts down, component cools off and starts it ascending to critical all over again. The longer you leave this problem the more costly to repair as it will eventuall spread to the other components overheating and possible fire.
Take it in for repairs now before it gets worse.
Please rate my help++++Thanks for using FIXYA
Won't turn on
The power supply module may have gone out, need to check and see if you do have 5vdc standby voltage at the power supply module, also check the fuse in the power supply.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
2helpful
2answers
Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television I have a 32" tv Westinghouse, it was on went I hear a sharp pop like glass breaking, I unplug it for a willy plug it back in and nothing happen what...
Ur power supply board is dead.Take ur tv aparts,replaced the power supply board.Ur tv will get ur power back an the tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2answers
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Wont turn on
What is the model #? Normally if the unit does not turn on or do anything when you press the power button you will need to replace your power board. You can find price and availability on with the Westinhouse parts department at [email protected].
I have a Westinghouse LTV-32w1 Televeision. My screen is cracked and I would like to replace it, as the TV works great. Where can I buy the screen?
You will pay more for the replacement panel then you will for repalcing the TV. The part number is LTV32W1-LCDP and is no longer avilable.
2answers
Audio Problem
Probably on the main board, most people use an external source for sound, tv does have a problem
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
