Question about Holmes Products HASF1516 Stand (Pedestal) Fan
Grinding of fan
I was taking apart my Holmes HASF1516 fan to clean it and now when I put it back together the fan hits the back of the back casing. I noticed that one of the screws behind the blades is loose and I'm not how to remove the actual plastic blades so I can get to that screw to tighten it.
Please help!
Thanks
Marc
  • 168 Answers
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Posted on Sep 11, 2008
  • James Coghill Oct 17, 2013
    I have seen some fan hubs unscrew counter-clockwise, but the general rule is simply that to remove, hold the blades in place and turn the hub in the same direction that the blades would turn in normal foreward operation. They are designed that way so that motor torque from normal usage, doesn't eventually work the hub loose.
    I meant to say that I have seen some that unscrew clockwise, or rather, that depending on the model and the direction of the motor in normal foreward operation, it could go either way.
I completely took apart my holmes air purifier to do a deep cleaning to get the fans and evreything dust free. need diagram to put back together. HAP9422 (model)
Hello, this is Ava with Think Crucial.
This is the manual of your Holmes model number: Holmes HAP9422 Product Manual Hope this was helpful.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
Ava B.
Think Crucial Customer Care
Apr 09, 2015 | Holmes Products Air Purifiers
Why is my Holmes HASF-1710 not getting power
This may be a duplicate post but here's my advice. Do a little disassembly to get to the "guts" of the fan. It is not uncommon for the speed control switch to break in such a way as to not allow the circuit to be completed. You may have to actually remove the switch and inspect it to be sure of this. I've had trouble finding replacement switches so I have put them back together with superglue. If this is your problem and you choose to use this solution just be sure all the switch parts get put back where they belong. If this is not your problem, break out the ohm meter and start checking your connections. Hope this helps
Jul 06, 2014 | Holmes Products HASF1516 Stand (Pedestal)...
Holmes heater
buy another one... take it apart making notes... put it back together... test it... if it works, you probably will be able to reassemble the one you have shown...
cmilton111
Oct 27, 2013 | Heating & Cooling
Clean fan
Flip open the latches around the cage to open that part up. Once open, turn the knob in the middle of the blade to the right. Normally iyou turn it left, but on this ne you turn right. That enables yo to remove the blade. Behind the blade is a rather large plastic nut, which you turn to remove and that takes the back part of the screen off. Use your vacuum to vacuum out the dust from the motor, the cages, and the fan blade. After that use a mild soap and water solution to wipe off the rest. I found it very helpful if you use a thick wet hand towel to clean the wire cage. It cleans it very well! Then just put it all back together again and your fan will look brand new.
May 30, 2012 | Holmes Products HANF96 Table Fan
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
How to remove blades of fan
First, make sure the fan is unplugged. Second, remove the front fan guard. Then to remove the blade you have to loosen the dome like nut nut at the center of the fan. This is a left handed thread so you will need to turn it the opposite direction (clockwise) of a regular nut in order to loosen it.
Aug 05, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
I have an HP dv9500 Intel laptop. The fan is making some pretty bad noises. I took the laptop apart according to the HP Maintenance Guide. I found tons of animal hair (I have two cats and a dog) and...
If there is nothing hitting the fan blades and the fan makes a grinding noise then the fan bearing is faulty. You may be able to place a drop of oil on the bearing under the label in the center of the fan and if this does not work then you need to replace the fan.
Apr 23, 2011 | Computers & Internet
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Jan 03, 2009 | Holmes Products Halls HLS5000-U Humidifier
Holmes Products HASF1516 Stand (Pedestal) Fan Logo
298 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
