Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence IC My TV is a Phillips 60PP8202 Rear Projection and I have an hour glass tv screen. I have been reading that I need to replace my IC's and I was wondering if anyone has any tips on where they are located, any how to suggestions and cost? Thanks, Brian
  • 138 Answers
Andrews Electronics www.andrewselectronics.com have an ETA of 9-6-8 on the part or you can contact www.wehaveparts.com I would either replace both IC`s or get a tech to do it, you can get them by calling this number 800-575-9833, they only sell the good ones,
Posted on Aug 19, 2008
The picture on my rear projection tv has an hour glass appearence. Both side of the picture are curved inward towards the center of the screen.
Hi , i will suspect your convergence board is defective you have 2 ic call stk for convergence correction and pin cushion
and some low value resistor and different bad soldering ,all this needs to be replaced and then reajust ,you must have a digital
array button on the front panel button some an automatic set up call majic focus wheres you must be able to realing this but if you dont have this button is probably locate on the convergence board anyway the circuit needs to fix befor any attempt to make any adjustement ,you may need a tech to do it, ic cost about 20 box each theres two on the board and s its an hour jobs about , depend on the tech experience...
hope that will help
regards Alan
Nov 01, 2010 | Toshiba 57H81 57" Rear Projection...
I have a HCL473W with a 'concave' screen effect on 2 colors??
You don't need to replace the whole board, regardless of which board it may be mounted on. The STK IC convergence chips alone are all that need to be replaced. You can order them from a number of different online sites. You can try Alibaba.com. If you have any more questions, feel free to ask!
Nov 08, 2009 | Samsung HCL473W 47" Rear Projection...
Looks like 3D with out the glasses
you need the phillips dptv 305 - dptv345 chassis convergence repair kit which contains both convergence ics and all feed resistors and also free installation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Insignia TVHD30 has picture that pulls in at the sides
HELLO it sound's like you need to set the convergence. on the set.!!! or need to replace the ic chip's on the convergence board. to fix your problum. "good luck"
Nov 25, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
The tv you sold me
pin cushion is gone.
time to get a new one.
don't try to fix it. not worth the time of the money.
Sep 24, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Zenith R49W36 Rear Projection TV Convergence IC problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
