Question about Gateway Computers & Internet
My computer keeps freezing up when i run a security scan or anything in my dvd drive. i have tried all kinds of thing to reinstall or fix the problem and nothing works. what should i do now? i even ran my operating system disk to try a startup repair and i didnot work either.
  • Gateway Master
  • 3,051 Answers
If you have recently installed any new devices i would try to uninstall the device and then see what the computer does please let me know ok regards mike
Posted on Aug 19, 2008
My laptop ( Acer Aspire 4736Z ) sometimes keep on freezing for a few minutes every now and then and its really annoying. I've tried defragmenting, updating drivers, used ccleaner, but the freezes are...
test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
a computer needs all of the data and power to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive
check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also
check the Cmos battery and computer ram make sure they are securely seated
you might have to many programs running at the same time you are playing games putting to much strain on the CPU
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don't need running select end now then you might uninstall that particular program you might have virus slowing your computer also select users you will see who is using your computer
also you might download and use this registry cleaner it is 100% totally free to use
http://download.cnet.com/ccleaner/
this should speed up your computer
if you need more help with this post a reply
Sep 18, 2011 | Computers & Internet
I don't what to do my thing freeze up for like
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
Jun 24, 2011 | Thermaltake Silent Purepower 480W...
VERY VERY SLOW CAN NEVER DO ANYTHING UPDATED EVERYTHING AND PLUS BUT THE INTERNET SERVICES IS SLOW ALSO PURCHASED A CLEANER FOR COMPUTER EVERYTHING GOOD WHAT IS THE PROBLEM GETTING READY TO QUIT THIS GAME...
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
May 25, 2011 | Computers & Internet
I have an acer aspire 5336 that has win 7 home premium. I noticed forthe past couple of days that my computer was getting really slow but today it completely froze so i restarted it and it goes to the...
when you put your hard drive in other computer try to fix your os using this way
go to run ()in windows 7 just type in search programs and files) type cmd, it will be c:\user\
type where your hard drive located for example D:
it will be d:\>
type chkdsk /f /r then enter
follow the next steps
May 22, 2011 | Acer Computers & Internet
My wii fit board keeps freezing
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
do not do anything while the chkdsk utility is in progress any input will damage your computer
also o
ne bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 24, 2011 | Computers & Internet
My computer wont eject my movie that i am really excited to see and i have to return the video today!!!HELP!!!! my com. keeps making these strange noises.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
make sure that the dvd is getting enough power test all leads that are attached to the dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
don
Feb 12, 2011 | Computers & Internet
I got a hp cd-writer cd12 series multiread cd-r/rw on a really messed up windows millenium edition computer yet it reads as cd-rom only drive i'm tryin to no success and will keep tryin to fix that so i...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
or
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
Dec 26, 2010 | HP CD-Writer Cd4re CD-RW Burner
Emachines 3240 - cannot recover
Download a Linux distro to a flash drive or DVD and see how well it runs off that. There's HDD utilities like SuperGrubDisk that can diagnose things.
Apr 04, 2017 | E-Machines Computers & Internet
Will not burn any dvds
Try upgrading the firmware.
2.) Try the drive on another computer to see if it works.
3.) if it does you might need to Format and Reinstall on your computer.
but it does sound as if the problem is with your drive rather than your pc if you got warrenty i'd suggest you take it back if not then try it on anoter computer to ensure its the drive before getting a new one
Oct 16, 2007 | Pioneer DVR-S111B DVD RW Dual Layer Burner
Computers & Internet Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
