Question about MTX Thunder 1501D Car Audio Amplifier
Mtx 1501d no sound
I have a 1501d that was working great when I shut it off. When I turned it back on later the red L.E.D. light comes on but no sound. The amp doesn't smell burnt. I unhooked everything and rehooked it back up just to check it over.... nothing. Hooked up another amp with same sub (15" 9500 mtx) and it worked fine. Does anyone know of same problem with these amps or how to fix. Thanks Fatcatfred
  • 1 more comment
  • Anonymous Sep 01, 2008
    i have the same probleme gos on red light but no sound comes out
  • Anonymous Dec 09, 2008
    is the 9500 a dvc or a svc??? i wanna say that the 1501 was a 2ohm stable amp,but you can still go under the ohms... i had 4 mtx9515's on 4 1501d's and i went under the ohm load and popped all 4 amps.... when you get a shot. mic the sub " voltage meter " and make sure that the sub is not throwing a bad load.... especially if the sub got warm it could clip the amp. and in turn pop goes the amp.....
  • monoblockluv Mar 13, 2009
    I have the same problem, i pulled the covers off and some of the transistors are totally fried. the ones that are visibly bad are....FET: 257 and FET:441,439,435,442,440,438,436. Also R436 (looks like a resistor) looks bad as well as R435. Does anyone know what these components controll? can i replace these?
    New Friend:
I have mtx 1501d and 81000d the 81 did same thing power with no sound.... layed amp down flat and it turned on. took lid off and not sure what they called but i put small chunk of padding on top of the lid so when i put my lid back on it pressed down on top the two round crazy looking balls of wires and bamb! amp was fixed still bumping it today mtx is great audio. its all i own. lol sorry guys in not sure what the things are called that need to be pressed onto board better but there was two of the right next to eachother and they red in color and are just bunch wire covered in glue.
Posted on Mar 08, 2013
  • 631 Answers
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
Posted on Aug 19, 2008
5kg top washer not working, making a continuous beep sound
1) Test the voltage of machine vs the outlet wall from the house,
2) See if the frequency is 60hz or 50hz?
3) Tight the connectors very well inside, and tight any loose wires
4) Reset the machine. Turn off the c.breaker by 15 minutes, and tripped again, and Turn on again. If the problem persist you must call some service tech, the board can be faulty.
God bless you
Jun 21, 2012 | Fisher and Paykel Washing Machines
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Need help MTX 1501d amp diagram
Remove cover and set in direct sunny window for long time, may be no problem with it, Took a month to dry one of my amps out enough that it decided it would come back to life, cell phone dropped in sink took 2 weeks, If you try power to it too soon --fried--, good luck finding diagram and repairing it sincerely-hope its okay, good amp, bad luck,
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
New ecu
I've had zero responses in the general forum so thought I'd try here...here's the story: I purchased a new ECU due to mine being kaput. The bike fires right up and runs great but... All attempts at reprogramming/mating the ECU to the rest of the bike have for lack of a better word failed. The issue? When I start the bike, the immobilizer light comes on during initial turn to on then goes out as normal. About 1 or 2 seconds later it comes back on and stays on. The bike runs great but this light is driving me nuts. When I shut it back off the immobilizer light flashes for 48 hours as normal. I've tried complete red-black-black-red key reprogramming but the dang light won't stay out when the bike is running. Any thoughts?,,,,
Nov 10, 2008 | 2003 Ducati ST4S
Mtx 1501D
if your power light is on then check your preamps (sub out from head-unit).Maybe you need to turn on that output thru head unit's audio menu.Also when using dual voice coils if you wire them out of phase there will be no output
Sep 16, 2008 | MTX Thunder 1501D Car Audio Amplifier
My led red light comes on but there is no sound
Have you confirmed that you have a good signal source and the speakers are in good working order?
If so, the amp has likely failed and will have to be repaired.
Let me know if you have any other questions.
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
MTX Thunder 1501D Car Audio Amplifier Logo
468 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
