Probe for cable/antenna is broken - Televison & Video
  • 54 Answers
Try another connection for an input such as the rca jacks or possibly hdmi. These should work even if that part of the set is broken. Good luck and please dont forget to rate me if this fixes the set!!!
Posted on Aug 19, 2008
6ya staff
SOURCE:
Tacoma(1997) power antenna mast with broken cord will not come out after the chrome nut is removed. Any suggestions? Antenna motor still works.
Power Antenna Mast Replacement 97 fjz-80 ' IH8MUD Forum
forum.ih8mud.com > Forums > Toyota Tech Forums > 80-Series Tech
Oct 1, 2010 - I'm looking for a "how to" on replacing the OEM power mast on a 97 LC. ... The only tricky part is removing the funky nut that holds the mast in. .... what to do with the radio mast on my newly acquired 1997 Lexus LX450. ... if I have a broken cable, but the antenna itself comes right out of the top with no cable.
How to rebuild the power antenna - Cadillac Forums
www.cadillacforums.com > ... > Cadillac Tech Tips - How to fix it
May 9, 2009 - 15 posts - ‎12 authors
Remove the liner to access the antenna and disconnect ANY of the two ... If notlocked the motor receives continuously power and will drain ... Broken nylon wire lifting/lowering the antenna mast 4. ... The motor shaft comes out from the plastic casing after you take out ... Do not lubricate the cable or the mast.
Saabnet.comt Broken Antenna FAQ - The Saab Network
www.saabnet.com/tsn/faq/antenna.html
If the cable broke in the antenna, you need to remove the antenna to remove the ... take a 17 mm wrench and remove the nut over the antenna where the mast comes out of the body. ... Hopefully the chrome sleeve will come with the old mast. ... Be careful not to drop them down too far. get the motor assembly on a bench ...Missing: tacoma ‎1997
How To Repair A Broken Car Antenna -EricTheCarGuy ...
? 20:53
https://www.youtube.com/watch?v=zcKwFto9_s0
May 24, 2013 - Uploaded by EricTheCarGuy
This video shows one way you can deal with a broken antenna. ... Find out why ... this video is that I did ...Missing: chrome
Jan 12, 2016 | 1997 Toyota Tacoma
Replace motorized antenna with a standard antenna on a 2004 Sonata
Antennas come with the cable
Remove the broken one first ,then
all your questions will be answered
Feb 08, 2013 | Hyundai Motor 2004 Sonata
Car antenna cable broken
cant find the car aerial cable from roof base
Jul 07, 2012 | 2003 Dodge Neon
How do you replace the antenna cable on a 2002 Chrysler Voyager
Yes you need to remove the liner and access it from there.
Oct 04, 2017 | 2002 Chrysler Voyager
My radio antennae does not work. I hear a
the cable inside that moves the antennae is broken. on many models you can just replace the antennae with cable instead of the entire unit whick will be a lower cost. ask at the volvo dealer.
May 15, 2010 | 1995 Volvo 850
Mazda Tribute 2001 automatic antenna is broken. Can hear the motor running but I think the cable is broken. Where can I buy an antenna mast aside from the Mazda Dealer.
If you hear the motor running, you are probably right that the cable that attaches to the antenna mast is broken. You should be able to buy this part only. Check Ebay. Sometimes you can buy the mast portion with the cable attached only. It's a lot cheaper than the whole assembly with the motor.Here's a link to one.
http://cgi.ebay.com/ebaymotors/Black-Billet-14-ANTENNA-2001-thru-2009-Mazda-Tribute_W0QQcmdZViewItemQQhashZitem588671d518QQitemZ380212729112QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Feb 12, 2010 | 2001 Mazda Tribute
The GPS appears to be stuck on & this drains the battery in about an hour when it is searching for satellites
Sounds like the spaghetti cable for the antenna is broken or has become unsoldered.... but to confirm...
Remove the reset probe from the top of the "pen" and insert it in the Reset hole in the back of the unit....
After the unit comes up, simply page over to the "obtaining satellites" page and see if you are getting signals. Of course you MUST be outside and you must NOT be under trees.
If no satellite data is received within 1 minute, your antenna (or its interfacing circuit) is not functioning.
At that point, repair is almost not worth it. You can get a new GPS for well under 100 bucks.... and Garmin will not even Look at your unit for that sum of money.
Nov 28, 2009 | Garmin iQue M5 GPS Receiver
How to replace arial in 95 camry
This is normally due to a broken antenna mast inside the motor, the mast /cable assembly should be replaced, the antenna motor has to be removed from the car and disassembled to remove the broken piece of the old cable, once that is accomplished the antenna motor is reinstalled and the new cable assembly is fed into the motor by turning the radio on until the motor stops and then turning the radio off while feeding the new mast in.
Sep 04, 2009 | 1995 Toyota Camry
Antenna motor has a very loud grinding noise. Antenna won't go up or down
THE ANTENNA MAST DRIVE CABLE IS BROKEN, EITHER REPLACE THE ANTENNA OR THE DRIVE CABLE, CALL THE DEALER TO SEE IF A ANTENNA MAST KIT IS AVALIABLE FOR YOUR CAR, MUCH CHEAPER THAN A WHOLE NEW ANTENNA..
Jul 09, 2009 | 2002 Mitsubishi Montero Sport
Saab 9-3 convertable antenna will not go up. there is a clickng sound when the engine is turned off and on at the antenna.
antenna mast is no good.. you can buy a mast and have it installed or buy a used antenna and have it installed im sure Elite foreign auto parts has only saab parts.. tested and used,
Feb 17, 2009 | 2003 Saab 9-3
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
