Question about Sony Cyber-Shot DSC-T1 Digital Camera
HOW DO I CHANGE THE COLOR MODES ?
I CAN NOT FIND ANYWHERE TO CHANGE COLOR MODES
  • 10,594 Answers
Please let me know what color mode you need in camera or what exactly problem in camera?
Posted on Aug 23, 2008
Screen has reversed colors (appears to look like a color negative). Everything seems to work ok. Repairable?
hello , just you need to enter to the picture options and change the display screen or display color , or change the mode it would be an NTSC mode you should change it
Feb 11, 2016 | Vizio VO370M LCD TV
How do I get color display? It's displaying black & white only.
it soudns like a cabling issue. What connections are you using?
Oct 02, 2015 | Televison & Video
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
HOW DO YOU GO TO SERVICE MODE ON A RICOH AFICIO 3224.I JUST FILLED THE OIL BUT STILL GETTING SAME ERROR SC570.DOES THE OTHER PIPE ON THE OIL TANK CONNECT ANYWHERE BECAUSE IT IS JUST HANGING THERE.
Hello Peter,
Once the device has been neglected for oil long enough you will get this error code. Usually people don't wait until the code occurs. You WILL INDEED need to go into service mode. To do this,you will need to follow a fluid 3 step process. First locate the "CLEAR MODES" key located obove the 9 key pad. It is yellow. Now locate the red STOP button located below the 9 key pad.Ok, to enter service mode you will need to press "Clear /Modes"and release,then press the numbers "1,0,7" in a 3 step sequence and release, then press the red STOP button and HOLD it down till the device beeps. The screen will change and say service mode. Press "COPIER". The screen will change again. Using the keypad press 5,8,1,0 and then press the pound sign {#}. You will be prompted/asked to EXECUTE. Press EXECUTE. Now unplug the device while in service mode after the execution of the 5810. Wait a sec, plug her up, and you are done. Have a good day and let fixya know I helped. :-) SPINAL
Jul 23, 2011 | Ricoh Aficio 1232C Color Copier
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
How to change the color mode on nikon d50
here is where to find the settings
press MENU button
select Shooting Menu (camera icon)
select Optimize Image
select Custom
the color mode is here. mode 1 is standard RGB
mode 11 is Adobe RGB
mode 111 is for custom color settings, it allows you to increase/decrease a number of settings relative to color.
once you make a change be sure to press the "done" button or your changes will be lost...
Jan 12, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
Wrong background color
Right click anywhere on your desktop.Make sure all programs are closed.Select properties,then select desktop.From here you can change it to anything you like.
Apr 11, 2010 | Acer AL2216W LCD Monitor
GC-822 Buttons Just Change the Color
After a mode is selcted by moving the mode slider switch left or right then depress that same mode slider switch like a button. When the mode switch is used to change a mode but one does not press it in to select it, that is when the play button changes colors.
Sep 20, 2009 | Sears GC-820 MP3 Player
Can we stop it from changing color
Hello bd1340,
The JVC KD-SC500 ships with the color selection set to "ALL DEMO" which alternates the colors approximately every 6 seconds.
To cancel the "ALL DEMO" and select a single color display, go into PSM mode by pressing and holding the SEL Button until the display changes. Use the left/right rocker until COLOR is displayed. Turn the VOLUME knob to select the color you want: Blue, Ocean, Purple, Pink, Rose, or Red. Press the SEL button again to exit PSM mode.
Hope this helps.
Aug 22, 2009 | JVC KD-SC500 CD Player
How to change back from B&W mode
I realized that the camera had to be in picture taking mode in order to be able to change from B&W mode back to color.
May 31, 2008 | Fuji FinePix S5000 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
26 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
