Question about Kenwood DPX-501 CD Player
DPX-501 LCD Repair
Did you ever get a chance to repair your DPX-501? If so, how did it go? Was it easy? Did it solve the problem?
  • iarocci Oct 26, 2008
    Don't bother, the LCD is NOT the problem. I replaced mine with negative results. Was a lot of soldering looking through a magnifying glass for nothing.
I got the new display part from the Kenwood supplier on LI, NY but there are dozens of pins on lining both sides of the display, each 1/16" from the other. I don't have confidence in my ability to detach the old and solder the new to the main board without further disaster.
Choices for me now are:
- continue "flying blind" - most likely solution for the moment.
- pay someone to do it - includes removal and being without a head unit for an unspecified time, plus cost.
- replace - I'd like to change brands although it means replacing the Kenwood satellite unit too, so more cost.
This hasn't been a good advertisement for Kenwood. People are impressed by the sound in my car, but not so much by the blank screen, guesswork changing stations etc.
I really like the unit, and the display was great while it worked: exactly as long as the warranty. I can't recommend Kenwood.
Posted on Aug 19, 2008
I left this camera out in the sun for 20 mins with the LCD screen facing up. Now when I turn it on the screen is so bright I can't see anything and can't use it. Can this be economically...
I'm afraid the chances of an economic repair are very slim, unless you can find an inexpensive used Z20fd and swap out the LCD screen. It most likely would not be easy in any case.
I wish the news were better.
Jul 13, 2011 | Fuji Finepix Z20fd Digital Camera
How do you get rid of a yellow line running down the screen
A yellow vertical line could mean that the Pixel controller is bad for that area on the LCD. It is difficult to repair, the only option is to replace the LCD screen. They are easy to replace.
This site gives you an example on how to r/r the LCD screen:
I buy mine from here:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe Diaz
Dec 27, 2010 | Toshiba Computers & Internet
I have a Kenwood DPX-501, and when I attach my Ipod Touch, it doesn't seem to work. Does the Ipod touch work on this stereo?
you need to call you local car audio shop and get a cable called a kenwood 301 ipod cable
Mar 20, 2010 | Car Audio & Video
How to solve the error 80040154
There are 3 step to repair 80040154 error
If you got 80040154 error then there is a 94% chance that your computer has 80040154 problems. To repair 80040154 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 80040154 error.
Here are the url of Perfect Optimizer:… Source(s):…
Mar 09, 2010 | Office Equipment & Supplies
Results after replacing the LCD panel
Same here. Replacing the LCD does not fix the problem. I wish someone could tell us what the real problem is.
Jun 14, 2008 | Kenwood DPX-501 CD Player
DPX-501 Root Menu Help
I emailed Kenwood USA and they gave me the number to an authorized Kenwood service center on the east coast( New Jersey). I sent them the receiver, and within 2 days they sent it back completely fixed. They even fixed an error code I didn't even know wasn't working. Price on the repair will vary depending on the problem. If it is fairly new and still under warranty then there should not be any cost to repair it.
May 11, 2008 | Kenwood DPX-501 CD Player
Kenwood dpx-501
I just solved the problem with my kenwood dpx mp 2090U - (looks similar with 501). FL Display with single CD, USB, 2 Din.
I should share this......... as I received the clue from someone that share the same case to me . Thanks to Mr,Nasirbaek from Indonesia,
The problem is at the main board . Dry (bad) soldering occurred. There are more then 5 resistors in series configuration. The resistor is quiet big (1.5mm x 3.5 mm, surface mount type R) about 2,7Ohms.The position is start from near usb port cable and ended to near big transistor (1 x 1.5 cm power transistor). After resoldering check with multitester to make sure that all R are connected in series configuration.
Just open 3 screws to access the main board. 1 at the top case. 2 at cd assembly, then Carefully take out the CD and the CD ribbon cable.
good luck.
Mar 25, 2008 | Kenwood DPX-501 CD Player
CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Jan 06, 2008 | Kenwood DPX-501 CD Player
Stand broke
Drop into your local TV repair shop. Chances are they will have a stand to suit it there.
It is a VESA standard screw pattern and easy to get.
They may charge you a few dollars for it, but for the chance of return business they may just give it to you for free.
Best to take the screen down with you to be sure though.
Oct 19, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
IPod Interface not working
That happened to me and the PFD Manual online said it means it's a communication error between the ipod adapter and the ipod. The ipod in my case was totally froze and I had to reset it using the hold on off then holding in menu and select for 10 seconds and it rebooted.
Sep 24, 2007 | Kenwood DPX-501 CD Player
Kenwood DPX-501 CD Player Logo
425 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
