Question about Dell 5100cn Laser Printer
5100cn Get error message 006-370 any suggestions on resetting the printer to get rid of error
  • 1 more comment
  • bmich1964 Aug 24, 2008
    I have cleaned the entire machine and when I go to print out reports it comes back with this error code everytime. I looked up the error code and it states that there may be moisture somewhere basically...and clues???
    Thanks for the help
  • rhslaven Aug 28, 2008
    Same problem here. Printer hasn't been hooked up for several months. Go to pannel and print a report i get message 006-370 Restart printer. Any suggestion would be helpful.
  • Randall Stoots May 11, 2010
    if you could supply me with a little more information regarding the error code and what exactly you are trying to do with your printer would help me pin point that error more precisely .... ok
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
The exact meaning of this error code ( 006-370 ) is <IOT ROS Motor Failure>. The SOS signal does not come from the ROS ASSEMBLY. What this means is the printhead, also know as Raster Output Scanner - laser unit. failed to generate a "start-of-scan" or SOS signal.
There is a humidity and temperature sensor in this printer that is designed to prevent the laser from being used in extreamly high humidity situations to prevent damage to the printer. This sensor rarely fails, and that is why it is the least likely cause of a true failure.
If in Fact you are in a high humidity situation. There is nothing wrong with the printer, and it will function normally when taken out of the humidity. Possibly running a dehumidifier in these cases will help. If this is not the case and are certain this is not the problem, then a true hardware failure has occured.
There are 3 possible causes for this failure, and they are listed in the most likely to least likely.
1) the ROS Assembly ( printhead, laser unit )
2) the PWBA MCU ( printed wiring board assembly - Machine control unit ).
3) Sensor assembly. ( humidity and temperature sensor )
Posted on Oct 02, 2008
  • David M. Haines Sep 12, 2013
    righton cory
    in fact when you press the next button it will show IOT 000003 or something like it , which "should" point you in the right direction of the failed component, allthough i have not personally mapped these failures.
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
I've getting the "Replace transfer roller" message
  1. reset count in printer menu
  2. clean the optical sensor
Mar 15, 2011 | Dell 5100cn Laser Printer
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
Replace Transfer Roller Error Message Will Not Reset After Replac
The transfer roller on this machine comes as an assembly consisting of a waste toner tank and a transfer roller. The message you are getting pops up when this tank is full, regardless of the transfer roller's useable life. There is a window on the back that when blocked by toner, cuts off an optical sensor to tell the machine that the waste toner is full. Just unclip the roller from the side, pop it out, and dump the toner out. Careful though, it's a messy job and you might want to wrap the assembly inside a trash bag while emptying it out.
Jul 01, 2009 | Dell 5100cn Laser Printer
How can I ignore the low toner error message and print black on a Dell 5100cn?
i believe that if you remove the color toner cartridges, it will stop asking and only print black. you may also be able to specify in the print menu settings to disable the color printing
Jun 10, 2009 | Dell 5100cn Laser Printer
Dell 5110 004-310 reset printer error
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
Jan 23, 2009 | Dell 5110cn Laser Printer
Error message on Dell Printer 3200cn 010-397
go to this link and go into the first Support Forum at the top off the page might help you out,if not just scroll down the page and you might find something to help you out.. Error message on Dell Printer 3200cn 010 397 Google Search
Oct 27, 2017 | Dell 5100cn Laser Printer
Error message
lisals, are you printing from a server? i may be able to help you... not 100%, but will try.
Jul 15, 2008 | Dell 5100cn Laser Printer
Error Message on Dell 5100cn
you select the cassete of your printer it is saying to put paper by manual feed
Sep 11, 2007 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
1,545 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
