Question about HP Photosmart 8250 InkJet Printer
What is error 0xc18a010a on for the 8250 hp printer
Im having a problem with my hp printer. It give me the ink system failed and can no long print. It gives me error code 0xc18a010a
  • 1 more comment
  • cjprnce25 Aug 25, 2008
    error 0xc18a0201
  • dbc123 Sep 08, 2008
    My 8250 Photosmart ( aka Photo-dumb) printer displays ERROR Oxc18a030a can no longer print ... "refer to user documentation"
    Printer is just a couple of years old, and has all new ink cartridges.
  • Hoofpick Sep 13, 2008
    Problem occurred suddenly, without warning, while in the middle of printing up vacation photos. It was as if a switch was flipped between one print and the next, with no unusual signs that the whole process was in jeopardy. Followed printer manual to "fix" problem to no avail. This stinks! Apparently, the printer only has a two year lifespan, according to other comments I've read on this site. Thanks, HP.
If you are not using HP ink cartridges you may have trouble. I was using Rapid Refill cartridges and had the same problem. I returned them and was told that a new chip has been installed in hp cartridges, so you need to make sure that the cartridges have this chip. Rapid Refill set me up and have not had any problems since.
Posted on Feb 26, 2009
  • 679 Answers
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
  • 210 Answers
I had a similar problem of a senseless printer error code with similar useless help from HP for one of my client's HP Photosmart 7510. I also could not find any other relevant help online. But, while searching, I did notice a suggestion to clean the contacts. When I removed the ink cartridge carrier, I noticed a large build-up of ink around the nozzles. Cleaning out the carrier did the trick for me. It couldn't hurt to give it a try.
Follow the steps below if you need them. And, please click "Yes" below if this has helped you at all.
Remove the carrier: Open the printer to access the ink cartridges. Slide out the ink cartridge carrier if it is parked. Remove all of the cartridges. Then flip the lever to the right of the carrier. Grasp the carrier using your thumb on one side and index/middle finger on the right, both near the top, and pull straight upward. Careful, yours may be more full of ink than my client's was.
Clean the carrier: Wash the carrier in a sink with warm/hot water at various angles until all noticeable ink is cleared away. Briefly wash water directly into the carrier's induction screens which contact the sponges of the ink cartridges. This may help a little to flush any ink from the nozzles which might have dried in them while the printer was inoperable.
Remove most of the water: Shake the carrier downward (only while upright) and tip the carrier forward and side ways. But, be careful since some ink will still be contained in the carrier's ink channels. Pay close attention to the induction screens. If you tip it too far or shake while inverted, ink may splash out through the screens or drain back onto the carrier. If this does occur, repeat the cleaning procedure.
Note: Do not attempt to drain all of the ink from the channels, whether through the induction screens or through the nozzles on the underside of the carrier.
Dry the carrier contacts: Lightly wipe the tiny metallic white squares on the backside of the carrier with a dry paper towel. Spot dry the surrounding area, including the nozzle arrays on the underside of the carrier - dab, don't wipe. You should get ink spots on the towel from the nozzles. This is to be expected and is a sign that the nozzles are not clogged (at least not completely).
Inspect the carrier transport: Examine the area with the metal prongs that were exposed when the carrier was removed. Dab dry any areas with ink if you find any, especially near the metal prongs. If you discover any ink on the prongs, use a wet, but drip-dried cloth or towel to continuously dab the prongs until they are clean. Then dab with a dry cloth or towel. Re-inspect and ensure any lint or other debris is removed from the prongs.
Reassemble and test: Return the carrier to the transport, flip the locking lever to the downward position, return the ink cartridges, and then test your printer.
I hope this helped and that all goes well. Please click "Yes" if this has helped you at all.
Posted on Mar 30, 2014
I have a HP 8250 printer....wont print. I get the following messaage. INK SYSTEM FAILURE The ink system has failed and can no longer print. Refer to printer documentation. ERROR Oxc18a0201. Turn...
Best simple fix is to take out entire program thru Control panel>add/remove and restart the computer and then reinstall it. Should take only 15 minutes.
Jan 03, 2011 | Office Equipment & Supplies
HP 8250 Photosmart printer that displays "system ink failure"
Try changing the ink cartridges.
If you installed the "HP Support Toolkit" software from the CD-ROM that came with the printer, use this Toolkit to "run a cleaning cycle".
It can print a "test" page, to show you which colours _do_ work, and which do _not_ work.
If all else fails, then find a qualified printer technician.
Dec 31, 2009 | HP - HP Photosmart 8250 printer
The ink system has failed and can no longer print. Refer to your documentation. ERROR 0xc18a0406
HP support has the following recommendations:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=443024&docname=c01458034#reset_product
Dec 06, 2009 | HP Photosmart 8250 InkJet Printer
Can't print on 8250 photosmart printer
See http://www.hp.com/pageyield/articles/us/en/InkExpiration.html on how to override error.
Apr 19, 2009 | HP Photosmart 8250 InkJet Printer
The ink system has failed and can no longer print. refer to printer documentation. error 0xc18a050a on a 8250hp I have a hp 8250 and I keep getting the error message 0xc18a050a. I tried reseting the...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP - HP Photosmart 8250 printer
Ink system failure
it could be a viros or a printer jam
Aug 16, 2008 | HP - HP Photosmart 8250 printer
Ink system has failed. unable to print. error 0xc18a0206
I find a solution 6180
unplug power cable
press 9 and # on keyboard
replug power cable with buttons pressed
the error must disapear
change the print cartridge indicated they became bad ( why ?)
reset is done you must reput language and network ip adress
Philippe GERARD
Jul 03, 2008 | Office Equipment & Supplies
HP Photosmart 8250 InkJet Printer Logo
1,162 people viewed this question
Seeker5211
Seeker5211
