Question about GE Spacemaker JVM1640SJ Microwave Oven
Removing an old old microwave oven
Model JVM48007. The GE microwave was manufactured in 1985. How do I remove it from the bracket above the stove / range??
  • hebetroyer Aug 21, 2008
    This is a very, very old micorwave. There are no screws at the bottom of the cabinet above the microwave that secure it to the cabinet. It is attached to a bracket with no visible scews or fastners to unscrew.
  • 25 Answers
Look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Posted on Aug 19, 2008
6ya staff
SOURCE:
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I need to know how to uninstall a GE spacemaker microwave oven model JVM250av001...any one out there know how..?
Put padding on the floor near by for a landing zone. Disconnect the power in the cabinet above. There are two screws in the upper cabinet that support the front. There is a wall plate that supports the back. When the two front screws are removed you will need to be supporting the microhood or it will fall. A strong assistant is nice to have. I like to have the stove out of the way so I can get under the microwave to support it. Once the front two screws are removed, tip the front down, pull the cord out of the upper cabinet. Then lift the back slightly to remove it from the channel on the wall bracket. Set it down Done.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
HOW DO YOU REMOVE AN OVER THE STOVE GE MICROWAVE ?
open doors of your cabinet above the microwave, look carefully toward the front you will see two screws one on either side, remove theses screws while a helper holds bottom of microwave, after screws are removed lift up on rear of microwave it will slide up and out of a rear clip mounted on the back wall. remove wall bracket and job is complete. oh yeah unplug microwave, or turn off circuitbreaker first. easy as 1, 2, 3. hope this helps.
Nov 05, 2008 | Microwave Ovens
GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Bought a new GE microwave MCD11E3W/MCD11E3B and the installation instructions and brackets were not included. the back bracked is there but it just would not hold the microwave. notice a few holes on...
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
543 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
