"Brick" means corrupting your Firmware, the system that makes your PSP run. Bricking can be caused by either "interrupted update of firmware" or attempt to install "PSP Hacks" also known as Jailbreaks or Custom Firmware (CFW).
Some PSP Models can be revived when bricked by using a system called "Recovery Menu" which becomes available when the PSP was running a CFW before it bricked. Another way of unbricking a PSP including those that runs Original Firmware is using Pandora Battery and a Magic Memory Stick.
However, there are PSP MOdels that cannot be unbricked. These are the PSP 2000 Slim that have the Motherboard TA088v3 and other higher end. The worst PSP Motherboard is the TA088v3 because once bricked, PSP becomes a lovely paperweight without game functions and possibility to be revived.
Hi.
It's when the PSP stops working because something went wrong while updating the firmware or when you try to downgrade the firmware version.
It's called a bricked PSP because the PSP basically becomes a brick. You can't turn it on or do anything with it.
Regards.
SOURCE: psp bricked
It means that the psp you use was hacked and the Sony company shut it down with a new update. Call Sony customer service and ask them, I'm not positive.
