Question about Microwave Ovens
My Sharp Carousel R-1406A microwave made a "pop" sound and shut off. Nothing works on the display either. The unit was manufactured in 1997. Is it worth trying to fix it? I checked to see if there was a reset or breaker, but did not find one.
  • Anonymous Apr 14, 2009
    where is the internal fuse?
  • 25 Answers
Internal fuses.
Posted on Aug 19, 2008
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Touch screen panel not working. in past unplugged and then plugged in again and it worked but now nothing
If you mean the display (the microwave works but no info on display) look here for a good diy thread:
Aug 12, 2011 | Sharp R-1750 Microwave Oven
The carousel turns but no light comes on inside, not is there any display light. Nothing works but the carousel. Thanks
That sounds like there is more than one fault, but maybe not. I suggest you get an appliance engineer in to take a look at it.
Jan 05, 2011 | Sharp R-820B Convection/Microwave Oven
Boiling water caused large "Pop" sound/microwave not working now
I would guess that the boiling water may not have been the cause ...
If you are lucky ... try this first:
Unplug or turn the circuit breaker off (if it is a built in unit). Wait an hour and then repower.
Odds are that will not clear things up ... but it is easy to try. Probably one of the electronic internals broke.
A number of different internal component problems could cause this heating failure in the microwave. It could be the magnetron, the high voltage transformer, the PC board, the diode, and the capacitor. This type of problem will need to be diagnosed and repaired by a service technician. Microwaves are inherently dangerous to service. This type of repair is not something that you want to try to do yourself. Internal capacitors in the microwave can retain a lethal electrical charge even when the microwave is completely unplugged. A microwave radiation leakage test should be performed on the unit using proper testing equipment following any internal component repair.
Jan 25, 2018 | Sharp R-1480 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Jun 11, 2009 | Sharp R-1870 Convection/Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Microwave Ovens Logo
281 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
