Question about Canon PIXMA iP6220D InkJet Photo Printer
PIXMA iP6220D doesn't use/recognize CL-51 cartridge
The CL-52 Photo cartridge is empty. I go into maintenance and select Color ink only, but it still won't print. Printer uses photo ink first even when printing black and white documents.
This printer won't work without both cartridges being installed. Have you tried checking the printer to see if the alarm has been cleared out? Hit the "okay" button and see if the ink cartridge selection updates. Have no clue about it using more photo ink rather than color unless your setting are not correct - paper type, etc.
Posted on Aug 19, 2008
    Problem Solver:
  • 37 Answers
Take the photo ink out.
6ya staff
SOURCE:
Tip
Replacing a FINE Cartridge on photo printer Prixma IP 6210D
If there is no improvement with the quality of printing following such maintenance as print head
cleaning, a FINE Cartridge is probably empty. Replace the empty FINE Cartridge with a new one.
When replacing a FINE Cartridge, check the model number very carefully.
The printer will not print properly if a wrong FINE Cartridge is used, or installed wrong.
When a FINE Cartridge runs out of ink, replace them using the following steps.
1 Ensure that the printer is on.
2 Open the card slot cover first and then open the front cover.
The FINE Cartridge holder moves to the left.
3 Remove the empty FINE Cartridge.
Color: CL-51 [High Yield] Photo: CL-52
The standard Color FINE Cartridge (CL-41) can be installed as option.
-Handle the FINE Cartridge carefully to avoid staining clothing or the
surrounding area.
-Discard the empty FINE Cartridge according to the local laws and
regulations.
on Dec 08, 2009 | Office Equipment & Supplies
Canon Pixma MP210 will not recognize high yield PG-50 & CL-51 cartridges.
The canon pixma mp 210 uses PG-30, CL-31, PG-40, CL-41
It will not recognized the PG-50 & CL- 51
See if you can return it and exchange it for the PG-40 & CL-41.
If not, the only other way is to transfer the ink into the other ink cartridges.
The cartridge cap can be removed by a sharp tap at the back end of the cover.
You can glue back the cover.
If there is an E 1,6 Error code, Ink has run out after you install your ink cartridges
Press and hold the stop/reset button for about 10 seconds to clear the error code.
Dec 24, 2010 | Canon Office Equipment & Supplies
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
What numbered cartridges go in what slot?
According to a web-site:
http://www.inkjetsuperstore.ca/printer-ink-cartridges/canon-pixma-ip6220d-toner-cartridge
replacement cartridges can be purchased from INK JET SUPER STORE.
Or, check the manufacturer's web-site:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=184&modelid=11863
and click on "supplies & accessories".
Dec 02, 2009 | Canon PIXMA iP6220D InkJet Photo Printer
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer won't accept cartridge
i sure u buy wrong cartridge for your MP450...if u want higher quality, u should buy CL-51 cartridge for colour and CL-50 for black..
fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
http://www.canon.com.my/section/inkjetPrinter/supplies/
hope this help... ; )
May 26, 2009 | Canon Pixma MP450 All-In-One InkJet...
CL-52 Photo cartridge not recognized
I go to Canons website and you may have to down load an updated device driver for that model or on there website you can search there data base for problems and fixes.
Jan 27, 2009 | Canon Pixma MP450 All-In-One InkJet...
Cl-41 to cl-51
You have ordered incompatible cartridges. You need CL38 (colour) and PG37 (black). They do not fit your machine. Send them back for a refund.
Aug 07, 2017 | Canon PIXMA MP210 Photo All-In-One Printer
Which ink cartridge to replace?
I have the same printer...its C 51 and P 52...this printer does not take black ink!!!!!!
Dec 09, 2008 | Canon PIXMA iP6220D InkJet Photo Printer
Canon PIXMA iP6220D InkJet Photo Printer Logo
507 people viewed this question
Clive
Clive
old marine
old marine
Ekse
