Question about Danby Portable Air Conditioner
Danby Portable airconditioner model number DPAC 120068
Purchased end of April worked fine till sat now will not cool aet cooling temp and wont set keeps going to room temp
  • 4736 Answers
SOURCE: I need to replace a
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 08, 2011
david04928
  • 102 Answers
SOURCE: Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
Posted on Mar 11, 2009
VtToolMan
  • 704 Answers
SOURCE: how to turn on the AC?
Here's a link to a site that has a free copy of your owners manual available. Just scroll all the way down and enter in the code shown and you'll be able to download the manual instantly.
http://www.devicemanuals.com/guide/Air%20Conditioner/Danby/Danby-DPAC120068-3-In-1-Portable-Home-Comfort-System-==TWpVME56TTM=.html
Hope this helps and best regards!
Posted on Aug 01, 2009
  • 68 Answers
SOURCE: Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Posted on Aug 03, 2009
  • 51 Answers
SOURCE: replace window mount for dpac 120068
GO TO DANBY.COM AND GET FULL SPECS FROM THE MANUFACTURERS WEB SITE. IF YOU WANT TO KNOW IF YOUR MAKING A GOOD TRADE OFF, LOOK FOR BTU'S , WATTS, AMPS, STAR RATING PER YEAR ETC...IF YOU WANT TO REPLACE JUST THE WINDOW MOUNT, THEN GO TO DANBY.COM, OR LOOK IN YOUR OWNER'S MANUAL TO ORDER A REPLACEMENT MOUNT. IF YOU JUST NEED TO KNOW HOW TO RELACE THE MOUNT , THEN CONTACT SUPPORT AT DANBY.COM AND ORDER WHAT YOU NEED, A MANUAL , INSTALLATION INSTRUCTIONS, GUIDES, AND IF YOU ALREADY HAVE THESE MANUALS , THEN JUST READ THE MANUAL ON HOW TO INSTALL A MOUNT OR REINSTALL A NEW ONE.
Posted on Apr 13, 2010
Our Danby model dpac 11006 was working fine yesterday but came to put it on today just to find out the ac doesn't work the fan still blows just no cool air . we do hear something in and out like a...
The intermittent sound you're hearing is probably the compressor trying to start. This could be caused by a bad circuit or the compressor motor is seized If the latter is the case, it's time to start shopping for a new AC. As the cost to repair would be almost as much as a new unit depending on the age of your unit. However, compressors usually have a 5 year limited warranty. So check you Owners Manual for details. It may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Danby Portable Air Conditioner
Danby 12,000 BTU Portable Air Conditioner - Doesn't Cool Enough
put a xtra fan on you to blow the cooler air around. this might help. but i think you will find it is to small to cool what your trying to cool. good luck and good day
saw
Jul 09, 2009 | Danby Portable Air Conditioner
Replace window mount for dpac 120068
Apr 13, 2010 | Danby Portable Air Conditioner
Everstar mpm08cr bb4 will cool briefly then briefly blow hot air
check your filter and replace,, and that dont do it,, you need to clean coils,, and if that dont work it may be low in gas,, hope this help you
Sep 01, 2009 | Danby DPAC8020 Air Conditioner
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
How to turn on the AC?
Aug 01, 2009 | Danby DPAC120068 Air Conditioner
Danby portable air conditioner does not cool properly. what do I do?
what temp range are you working with here? are the filters clean? we need to know what Air on temp is and Air off temp.
Jun 24, 2009 | Danby Portable Air Conditioner
Unit does not cool with the exhaust pipe connection covered
you need to get the exhaust air out if the structure or it will never work, you can use regular duct from a supply house as a temp fix
Jun 01, 2009 | Danby DPAC10031 Air Conditioner
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Room temperature has not changed since hooking up new portable a/c
This may sound dumb but ( 1) Do you have the warm air from the unit to the exterior of the space? If the condenser is in the space your putting the heat your trying to remove right back into the space. ( 2 ) There should be an air supply and an air return in the space only. With that there should be a temperature difference of 16 to 20 degrees between the supply and return. ( 3 )A 1 ton unit usually will cool approximately 400 square feet. ( 4 ) It may take a while to pull the space temp down due to pulling the heat and moisture from the ceiling, walls, and floor. This could take 6 hours or more the first time you use the system in a space.
Danby Portable Air Conditioner Logo
581 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
